585,956 active members*
4,436 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Panasonic 400W AC servo running on Leadshine 200W AC servo Driver for testing?
Results 1 to 7 of 7
    Sep 2011
    474
    I have a set of 5 of these 400W AC servos. Model: MUMS041A1E0S
    Attachment 298316
    Attachment 298318
    I cant seem to find a pinout anywhere. I have a driver here that was recommended to me. Here is the pinout of the driver in question:
    Attachment 298320
    Does anyone have any suggestion? I'd like to be able to confirm that the servos work properly even at half power.
    Thank you all in advance
    SD
    Feb 2007
    711
    Re: Panasonic 400W AC servo running on Leadshine 200W AC servo Driver for testing?
    A B and Z will match up, not sure about RX or the UVW Hall inputs.
    Attachment 298322
    Attachment 298324
    Sep 2011
    474
    I have an occiliscope. Will that help me figure out which is which?
    Quote Originally Posted by alan_3301 View Post
    Attachment 298322
    Attachment 298324
    Feb 2007
    711
    I don't know. You could probe them and see. I'm not sure what they are in reference to.
    I'd just give the encoder 5v/ground and scope the outputs. RX may not be needed.
    Does that drive need both ABZ and Hall UVW or just one or the other?
    Why did you get a 200W drive for a 400W motor?
    Sep 2011
    474
    Well, I had the drive on hand and I really just wanted to test the servos out before selling them. They came from equipment that was used once so I see no reason why they shouldn't. Is there a better drive available I can use without shelling out the cash for a panasonic 400W driver?
    Marty
    Feb 2007
    711
    I don't think there is that much demand for a random servo with no drive. Anyone who is willing to pay a fair price will just buy a matched set.
    Unless you can properly test those motors, there is no point in seeing if they will spin hooked up to some random drive.
    I would probably just do a resistance check and show that there are no shorted or open windings. If you have an inductance meter, that is another measurement you can make.
    Sep 2011
    474
    It seems I remember people running these on Leadshine drives. I agree that finding comparable Panasonic drives would be ideal. Are there any other manufacturers that make comparable drives that you know of?
  1. Panasonic AC servo driver
    By croco85 in forum Servo Motors / Drives
    Last Post: 07-25-2015, 03:21 PM
  2. WTB: AC servo + driver 200W
    By sco_27 in forum Want To Buy...Need help!
    Last Post: 08-19-2014, 05:37 PM
  3. Panasonic Panadac AC servo motor driver
    By luckym in forum Servo Motors / Drives
    Last Post: 05-15-2010, 09:24 PM
  4. Panasonic Servo and Driver
    By Jim_the_one in forum Servo Motors / Drives
    Last Post: 06-25-2008, 08:43 PM
