585,997 active members*
4,844 visitors online*
Results 1 to 6 of 6
    Aug 2015
    12
    Wiring dilema
    Hi.
    I have 3 axis kit with Nema 23, DM542A drivers and DB25-1205 Breakout board. So far I am figured out how to wire stepper and power supply. But when it comes to wiring BB and driver there is problem. On internet I have found different solution
    and dont know which one is right (dont want do wire something wrong).
    So my question is, how to wire BB with this driver?
    May 2005
    1397
    Re: Wiring dilema
    Why not ask the people you purchased it from? Don't they provide support?
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
    Jun 2014
    777
    Re: Wiring dilema
    Bob to driver is simply pulse pair and direction pair
    May 2009
    26
    Re: Wiring dilema
    I have uploaded circuit diagrams of how I wired my router. Hope this will help you. Shout if you require further help.
    Kind regards,
    Les
    Aug 2015
    12
    Re: Wiring dilema
    Quote Originally Posted by Les Bidgood View Post
    Kind regards,
    Les
    Thanks man, you really helped me.
    Sep 2018
    Re: Wiring dilema
    Hi . I like your wiring diagrams, It is crystal clear! I noted that you used the common cathode wiring method. How did it work for you? I am at the final decision between common cathode/anode. Most blogs argue that the anode method yield better results ;however I prefer the common cathode wiring method especially with the isolating power supply. Any pointers for me ?
  1. New cnc router dilema
    By alexhhisc in forum DIY CNC Router Table Machines
    Last Post: 03-14-2013, 09:31 PM
  2. Tooling dilema
    By photomankc in forum Benchtop Machines
    Last Post: 07-17-2010, 08:55 AM
  3. Turning dilema
    By JDenyer232 in forum Haas Lathes
    Last Post: 01-26-2010, 11:42 PM
  4. CAM software dilema
    By greenchair in forum Uncategorised CAM Discussion
    Last Post: 11-08-2009, 07:29 PM
  5. Dilema
    By metalcraft.hr in forum CNC Machine Related Electronics
    Last Post: 06-11-2007, 08:07 PM
