Hi All!
I'm new to cnc/laser cutting topic, pls help me.
I want a machine only to cut 1.5mm thick nylon webbing, and put holes on it. I need some cheap solution, thats how I found K40.
I want to be able, to put holes in a consistent way, and make a rounded cut at the end of the webbing.
My plan is to make some kind of guide to place more webbings parallel side-by-side, and then I can start the cutting program, to cut them the same way, and make the holes.
So all I need is consistent execution of a simple cutting, nothing fancy engraving, or cutting.
I read a lot about converting, and upgrading, for better accuracy, and better use. (DSP, and different logic boards)
However I'd like to ask you, whether I'd really need any upgrade, for simple jobs that I want?
What upgrade would you say the most important for my needs?
thanks all
