586,005 active members*
5,003 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > Post processor formats?
    Oct 2015
    Title self explanatory I hope.
    I have seen several formats (scpost, VPL, Tap, etc.) last one is not a format
    is there any actual difference between them?
    Aug 2014
    12
    Re: Post processor formats?
    Quote Originally Posted by HamdiHirz View Post
    The formats you have listed are file extensions. Inside the post processor file, there is the following line:-
    Extension = "VPL";
    Whatever is inside the "" is what the extension is set to. Different posts will use extensions to suit the machine the post was created for. There are huge differences in each post processor
    Apr 2003
    416
    I posted my gcode with the "mach3mill.cps - Generic Mach3Mill"
    It adds the .tap extension to the posted file. (could not change the extension in the Fusion configuration screen)
    I renamed the file with a .nc extension and runs fine on my mach3 router.
  1. Replies: 1
    Last Post: 01-02-2021, 11:05 PM
  2. Question about CAM/CAD formats
    By nadsab in forum Uncategorised CAM Discussion
    Last Post: 11-19-2011, 01:11 PM
  3. Program Formats
    By Ashish B in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-27-2009, 12:08 PM
  4. Replies: 2
    Last Post: 10-30-2008, 01:40 PM
  5. File formats
    By pinkerton5 in forum Solidworks
    Last Post: 12-27-2005, 09:04 AM
