Hi-
I'm testing the Ethernet Smooth stepper on my machine. Everything is working fine except the spindle speed control. ESS does not seem to recognize the spindle sensors and overruns the speed.
EXAMPLE- Using my old parallel port connection and giving an M3S500 command, the spindle will run up to about 750 rpm, then settle back down to 500.
Using the ESS, the spindle runs up to 750 and stays there.
I have spent a couple days going through all sorts of variations of settings in Mach 3 and the ESS plugin configuration without success. I have even changed Ethernet cables and ribbon cables.
I have pretty much concluded that the ESS is not reading the spindle sensor signal for some reason and was hoping some one out there had figured this problem out already.
Thanks in advance for any help.
