584,850 active members*
4,210 visitors online*
IndustryArena Forum > Material Technology > Hard / High Speed Machining > Drill holes at an angle in superalloy....and deep too
    Jul 2007
    72
    We have a upcoming project in A286 iron base superalloy HRC 32 flat stock
    (30) .276" holes drilled 1.25" deep at a 50 deg angle to cross holes
    and
    (42) .197" holes drilled 1.05 deep at a 60deg angle to cross holes
    Should I pre drill with a short drill first or go in with an endmill and make a flat
    Also we are considering drilling deep holes in this part
    (2) .313dia 17.23 deep
    (4) .375dia 17.3 deep
    Any advice on sfm and chipload on carbide drills would be appreciated, along with any other things to look out for.
    I'm just a butcher masquerading as a machinist
    15362
    Re: Drill holes at an angle in superalloy....and deep too
    Quote Originally Posted by gogego View Post
    and
    You have to make a flat the dia of the drill you will be using, spot drill then drill your hole
    For your deep holes you will have to Gun drill them
    Mactec54
    Jul 2007
    72
    How about feeds and speeds for drilling and milling
    I am seeing about 30 sfm and .002"ap for tooling around 3/8" or a little smaller?
    Also seems that hss steel is used more often than carbide.
    15362
    I think you will find something close enough in this PDF
    Attached Thumbnails Attached Thumbnails GuideToMachining2002.pdf
    Mactec54
  1. Tapping 3mm holes at 5mm deep
    By dalianharley in forum Tormach Personal CNC Mill
    Last Post: 06-09-2014, 10:04 PM
  2. How to drill a deep hole using U drill on floor boring machine
    By SatishNaik in forum News Announcements
    Last Post: 10-15-2013, 12:58 PM
  3. Deep holes
    By keithmcelhinney in forum Novakon
    Last Post: 09-17-2013, 01:09 PM
  4. Replies: 8
    Last Post: 01-25-2008, 04:12 PM
  5. deep drilling 2mm holes
    By kesparate in forum Uncategorised MetalWorking Machines
    Last Post: 09-16-2007, 05:57 AM
