585,991 active members*
4,725 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Fadal 4020 - low spindle rpm
    Sep 2011
    9
    I need help with VMC4020 with AMC and spindle with 10000rpm
    I found, that spindle has wrong rpm,but noerror message.
    LOW range: programed 0 - 2500 rpm: real rpm 0-800 and then still 800rpm
    HIGH range: programmed 2501-10000rpm: real rpm 0-3200 and then still 3200rpm only
    Where could be a problem ?
    May 2015
    70
    Re: Fadal 4020 - low spindle rpm
    Check the spindle drive parameters.
    Sep 2011
    9
    Quote Originally Posted by Mike283 View Post
    how ? "SETP" ?
    Sep 2011
    9
    SETP: 10.000 LOW/HIGH, GAIN 100 (range 0-255), RPM 0 (range 0-31)
  1. Fadal VMC 4020 - Spindle Load Problem
    By phat in forum Fadal
    Last Post: 07-14-2016, 10:28 PM
  2. spindle will not stop fadal 4020
    By choppermex in forum Fadal
    Last Post: 06-17-2016, 09:59 AM
  3. 4020 fadal spindle orientate failure
    By beekeeper in forum Fadal
    Last Post: 10-09-2010, 10:53 PM
  4. spindle orientation fadal 4020
    By atlantic23 in forum Fadal
    Last Post: 10-26-2009, 03:20 PM
  5. HELP ASAP with Fadal 4020 Spindle
    By TurboBlazerX in forum Fadal
    Last Post: 04-21-2009, 03:15 PM
