585,949 active members*
4,083 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Bad finish with scallop control on a Haas
    Nov 2015
    I am getting a terrible finish using a sallop height control from MasterCam on a Haas 3-axis finish. I am finishing with a 1/8" ball cutter in Aluminum. My feedrate is 100 in/min, and my RPM is 10K. G187 P3 E0.001, and using HSM. The finish is O.K. on constant z-levels, but not on the 3-d surface scallop height control tool path. Seems like the cutter is stopping at each end of the polyline when the tool path is not on a constant xz- or yz-plane.
    Any ideas of what is going on? Anyone else has experienced this phenomenum? I have a picture that illustrates the issue: it looks like little pecks or dots on the surface as if the cutter all of the sudden stopped and jerked a bit.
    Scallop-height type of tool path used
    The dots in the finish are randomly generated.
    Re: Bad finish with scallop control on a Haas
    Hi did you ever figure out how to fix this, My HAAS is doing same thing!
  1. Control plunge Speed in Finish Waterline
    By photomankc in forum SprutCAM
    Last Post: 01-31-2015, 02:36 AM
  2. Toolpath Scallop - What is the Step down?
    By cordvision in forum Mastercam
    Last Post: 12-18-2013, 08:30 PM
  3. Scallop removal
    By cgroves in forum SprutCAM
    Last Post: 09-27-2010, 01:27 PM
  4. Scallop Toolpath
    By jcnewbie in forum Mastercam
    Last Post: 11-02-2009, 02:17 PM
  5. Replies: 11
    Last Post: 06-01-2007, 04:03 PM
