585,733 active members*
4,945 visitors online*
    Jan 2007
    311
    Pendant looses conection
    I've got a iMach3 M1 USB CNC MPG Pendant Handwheel from VistaCNC
    Every once in awhile it looses connection to the tormach. Seems to be when it's not used for awhile, like when cycles are running and then I need to adjust something and sometimes it's fine, others it's quit responding.
    The main led stay lit but the ones down on the control buttons (axis and function) go out and nothing works on the pendant. The keyboard and mouse still function normally.
    If I unplug and plug it back in the computer says it is installing new hardware but it still doesn't work.
    If I close mach and reopen it everything goes back to working fine.
    One day it might work perfect, the next day it might work ok in the morning, then stop responding sometime in the afternoon. restart Mach and it's fine again for the rest of the day.
    Anyone else encounter this before?
    M
    Jun 2014
    1780
    Re: Pendant looses conection
    I lost the pendant connection as well as usb ports intermittently with Mach 3, The Vista pendant I have doesnt work with Pathpilot, but I haven lost a usb port since I installed it.
    mike sr
    Jan 2007
    311
    Hmmm, never thought about the pendant not working with PP, what control do you use (I'm guessing Tormach's wheel thing)
    M
    Feb 2006
    7063
    I suggest you get in touch with VistaCNC. You'll find the owner, Lee, to be very helpful.
    Regards,
    Ray L.
    Jun 2014
    1780
    Quote Originally Posted by Mooser View Post
    M
    I am using pathpilot and the Tormach shuttle controller, I do have a vista pendant but it doesnt work with it so far. I think a few of the guys have gotten it to work but takes some knowledge of linux programming to accomplish it.
    mike sr
  1. DNC hardware conection
    By aparecer in forum Computers / Desktops / Networking
    Last Post: 09-27-2022, 12:47 AM
  2. proma thc conection to logitrol board
    By ciccio15 in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 06-29-2014, 11:03 AM
  3. Need help with contoller drive board with parallel conection for the STK672-050 IC
    By tony2025 in forum CNC Machine Related Electronics
    Last Post: 09-28-2009, 07:50 AM
  4. Replies: 0
    Last Post: 09-22-2009, 12:15 AM
  5. mitsubishi encoder conection
    By rosli in forum Servo Motors / Drives
    Last Post: 10-18-2006, 12:48 AM
