584,849 active members*
4,227 visitors online*
Results 1 to 8 of 8
    Nov 2015
    5
    Z axis direction
    My z axis is moving in the wrong direction.
    After zeroing work -z goes up and +z goes down into work.
    How can I reverse this?
    x and y are also reversed.
    Any help out there?
    Jun 2014
    777
    Re: Z axis direction
    Try going to ports and pins and checking or unchecking active low on z motor direction pin
    Nov 2015
    5
    Thanks for the reply.
    Unfortunately the software I am using (eding pc based cnc) doesn't give me options to change motor direction. It gives option to invert the jog keys direction. is this the same thing or is it just inverting the keyboard for easier handling?
    Switch one pair of wires on the stepper drive.
    Either A and A+, or B and B+.
    Nov 2015
    5
    I'm afraid I don't feel confident to do this as the wires are not labeled.
    Thanks anyway
    Nov 2011
    In the Setup tab under Steps/AppUnit you can put a minus sign in front of the number and this should reverse the direction. Don't forget to click the save changes button.
    Attachment 299894
    Nov 2015
    5
    Thank you for your advice and the screen shot. I will try this. Unfortunately I have just had to send back my control unit to be repaired due to a problem with the running of the spindle so I will have to wait but your answer makes sense.
    Cheers!
    Apr 2009
    5516
    Quote Originally Posted by red2002 View Post
    Any help out there?
    In the steps per box, put a negative (-) sign infront of the numbers... Done!
  1. New 4th axis one direction only
    By speedtwin69 in forum Taig Mills / Lathes
    Last Post: 11-22-2012, 04:39 PM
  2. X axis works fine but Y axis direction is erratic
    By swampbud1 in forum DIY CNC Router Table Machines
    Last Post: 12-07-2010, 12:28 AM
  3. C axis direction
    By riverking in forum Daewoo/Doosan
    Last Post: 12-09-2009, 01:38 AM
  4. Need Direction on 4th 5th? axis program
    By Cappy in forum GibbsCAM
    Last Post: 04-21-2007, 01:20 AM
  5. z axis direction question.
    By ljoe1969 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-22-2004, 02:53 AM
