Hi this ken from Thunderlaser, now we’re going to show you how to use the Laser cutter software – the RDworks V8.
The most frequently used tools are listed on the left side of the software. We can use these tools to draw simple graphics.
The first one is a line drawing tool; you can use it to draw lines easily.
Press “Ctrl” while dragging the mouse to draw a horizontal or vertical line.
The second one is a polyline tool. You can use it to draw polylines freely. When you need to draw a closed figure, you need to double click the left mouse button.
The third one is a Bezier tool; you can use it to draw any kinds of figures freely.
The forth one is a square tool, you can press “Ctrl” to draw a rectangular.
The fifth one is a circle tool, you can press “Ctrl” to draw a perfect circle.
The sixth one is a text tool; you can double click to popup a dialog. Then input the words and press “Enter” to start from a new line.
You can set the width of the letters and fonts etc. Press ok to confirm you input. You can double click the texts to re-edit it.
That’s all for this lesson, see you next time.http://www.thunderlaser.com/video/ho...e-graphic.html
