585,982 active members*
4,690 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Changing the default post processor
    Jan 2012
    55
    Hello All,
    Can someone walk me through how you can change it so that when you post out with Mastercam it will default to .cam instead of .nc
    I did this with some help a couple of years ago and can't seem to remember how I did it.
    Thanks for the help!
    Dale
    Jun 2015
    76
    Re: Changing the default post processor
    Hi
    You can change the nc file extension in the control definition under files. Have you tried that?
    Cheers
    Dec 2008
    3109
    Quote Originally Posted by Uhrenholt View Post
    Hi
    Cheers
    No........that only alters the control file for that session file
    For the method to do permanent changes
    - you have to open the Machine definition file first....then select the control icon on the toolbar in that dialog box
    Your MMD file is what is called when you select a CNC machine.......which holds your machine specs, the Control & post files
  1. Changing the default post processor...
    By DavidMc0 in forum BobCad-Cam
    Last Post: 06-04-2015, 08:15 AM
  2. Post Processor: Changing the format of feed output.
    By somebodyelse in forum CamBam
    Last Post: 01-16-2014, 03:33 PM
  3. changing default settings
    By routalot in forum Rhinocam
    Last Post: 09-27-2013, 08:45 PM
  4. default depths not changing
    By hatchmar in forum BobCad-Cam
    Last Post: 07-18-2012, 01:12 PM
  5. changing a post processor
    By fourperf in forum Fadal
    Last Post: 06-16-2007, 04:48 PM
