585,975 active members*
4,877 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > Fusion 360 import spline - Create weave shape - post gcode
    Apr 2003
    416
    I am impressed with Fusion 360. Just using free version for a hobby.
    I was going to try to write a python script to import a spline, but there was already one there in the sample file-scripts and addins.
    Generated a sine curve in excel (saved as CSV)
    used Sample script "importSplineCSV"
    Extruded a circle along the spline path.
    Copied the body and added a block under it:
    Attachment 299966
    Posted Gcode and ran in Cutviewer:
    Attachment 299968
    NC file was 79000 lines long runs over 2hr at 20ipm (6x6 inch, using a 1/4"bem)
    Getting ready to try it out on the router.
    Apr 2012
    32
    Re: Fusion 360 import spline - Create weave shape - post gcode
    I don't know what that is, but it's cool.
    Apr 2003
    416
    Just playing around learning Fusion.
    It's just a pattern to carve into piece of wood. Hope it looks cool there too. I'll post a pic when I get it run.
    Apr 2003
    416
    Finally got back to running the cnc file on this weave pattern. Still don't know what it is.
    http://wjbzone.com/cncprojects/20200422_105214weave.mp4
  1. Expoting a DXF file from 2020 Fusion to import and use in Biesseworks
    By Rooster82 in forum Uncategorised CAM Discussion
    Last Post: 11-12-2013, 05:52 PM
  2. Chuck Arbors - Import or...Import?!
    By scorpion in forum MetalWork Discussion
    Last Post: 10-23-2012, 07:08 PM
  3. Take a look spline job
    By turboless in forum Employment Opportunity
    Last Post: 05-22-2009, 04:04 AM
  4. spline help,mc9.1
    By GRANDPA in forum Mastercam
    Last Post: 03-10-2007, 01:00 PM
  5. Spline
    By scottsss in forum Autodesk
    Last Post: 07-15-2003, 04:30 AM
