I wasn't happy with the stock Fogbuster mount. There are two main problems. First, the magnet doesn't stick the the Tormach PCNC1100 spindle casting very well. I don't know if it's really thick paint or something with the casting. It sticks fine to other objects like sheet metal or the table. The result is it moves on it's own too easily. The second thing I didn't like is how it's adjusted. It's just not easy to quickly position the fogbuster where I want. I thought some sort of stiff flexible arm would work better. First I tried a Magic Flex Arm used to hold photography lights, but this didn't work too well, the arm is pretty stiff, but it's hard get it to the right position, it moves after you let go. Next I tried 1/4" loc-line and this works pretty well. Even though I like the 1/4" loc-line, I may try using 1/2" loc-line and see if I like that better.
Attachment 300282
