Ok, this should have been an easy part to draw and make. Well it isn't turning out that way.
Slot depth 0.630" Three different width 0.690:, 0.438" and 0.500". Next slot is from -0.630" down to -1.25" not as long and 0.690" and 0.438". The third slot is from -1.25" down to -1.35" and 0.031 wide.
I'm using my Harbor Freight mini-mill that's converted to CNC using MACH 3 for a controller. Oversized balls are in the ball screws and are repeatable less than 0.002" Cutter is a 0.375 three (3) fluted carbide cutter depth of cut 0.100" at 10 ipm.
I'm cutting machine wax to proof out the profile before putting aluminum in the vise. The part is continually undersized. up to 0.020" but not consistent in width or depth.
The attached file I've continually increased the width to get to a measurement on the part that meets the print. It's still off at 0.700" on the large slot.
Please advise.
John
