585,932 active members*
3,809 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Help with Fancu M11 ATC needs adjusted
Results 1 to 2 of 2
    Nov 2015
    I adjust so that my arm in the toll removal mode and when it goes back to rest the arm is setting about 10:00 and 4:00. That is in the direct path of the my Z axis. Kitamura said loosen the taper lock and move the arm so that it lines up. When I do that either the arm doesn't get to the tool to remove it (while in rest the arm is at 9:00 and 3:00 perfect). Or if the arm lines up at the tool then in rest it is at the 10:00 and 4:00 position.
    Nov 2015
    Re: Help with Fancu M11 ATC needs adjusted
    Got it
  1. Fancu 10M IPL Mode problem...
    By madkins in forum Fanuc
    Last Post: 01-21-2019, 05:27 PM
  2. Help with Fancu M11 ATC needs adjusted
    By Dor91 in forum USA Club House
    Last Post: 12-08-2015, 02:49 PM
  3. Look ahead (GI) adjusted machining time estimation
    By Paw1 in forum Uncategorised MetalWorking Machines
    Last Post: 07-04-2012, 05:13 PM
  4. Fancu 3 look-ahead?
    By brgrii in forum Fanuc
    Last Post: 11-11-2010, 08:35 AM
  5. Axis movement speed adjusted by pressure sensor
    By Viesturs in forum Controller & Computer Solutions
    Last Post: 05-20-2009, 12:44 PM
