Hi
I have recently finished building my Steel Router with a working range of 920mm x 600mm x 140mm and it worked fine except that the motors continually lost steps while cutting even at quite slow speeds.
The general opinion on this forum was that the 1 nm Motors that I fitted were not powerful enough for my size of machine.
So I have now bought some new 4.5nm motors and electronics to 'beef' up the machine.
The Guy that supplied my original electrics wanted £600 + all my old electronics and wiring returning to upgrade to a more powerful setup.
So I decided to source the parts myself.
Here is the list of the new parts that I have bought from Motion Control :-
2 x 8 wire 4.5 nm Stepper Motors for the X & Y Axis
1 x 6 wire 4.5 nm Stepper motor for the Z Axis
3 x MDS542 4.2amp Driver
2 x 42vDC 280w Power Supplies (The guy recommended that I bought two to be on the safe side, and to 'gang' the outputs together)
1 x Breakout Board
1 x 4 Relay board to drive my Router and Dust Extraction system.
The reason for the different motors is that they only had 2 in stock, the guy said the 6 wire motor would be fine for the Z Axis.
This weekend I would like to get the parts up and running on the bench, and I could do with some help from the electrical Gurus that are on this site
Electrics are not my strong subject and bring me out in a cold sweat so please be gentle with me
I do have a multi-meter available if required.
Now onto the questions :-
1) The X & Y Motors have 8 wires, how do I wire these into the A+,A-, B+ B- on the driver.
2) The Z Motor only has 6 wires, one of these is just a 'bare' wire with clear insulation on it.
How do I wire these into the A+,A-, B+ B- on the driver.
3) On the PDF file attached for the driver it shows a typical wiring diagram and it shows 3 x 270 ohm resistors, are these already fitted internally, or do I need to add these?
4) In my enclosure I have only 240v AC and 42v DC available, what is the best method for me to power a 12v cooling fan?
5) I have my original box and working Mach2 file to get all the pin numbers for the limit switches etc. What pins on the parallel port would I use to switch the relay card on & off?
6) What pins do I use on the Breakout Board for connecting the Driver PUL+, PUL-,DIR+, DIR-, ENA+, ENA-
Thanks in advance, it is very much appreciated.
Andy
