585,951 active members*
4,129 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > question about solid works sketch to bobcad
Results 1 to 11 of 11
    Aug 2014
    161
    So I'm making a pcb board for a probe, I drew out a sketch in solid works cause I don't like bobcad, is there anyway to open that in bobcad and use it to make the tool path? Without actually making a 3d part, basically the tool path would just need to cut around single line with a v tool. Thanks
    Sep 2012
    1195
    Re: question about solid works sketch to bobcad
    I'm not sure that a sketch will mean anything to Bobcad since it is sort of used as background information for Solidworks, or at least that's the way I understand it. If it doesn't show up, there probably isn't any way to use it. I have had clients export DXF files from Solidworks, so maybe there is a way to export sketches as DXFs?
    Sep 2014
    Bear on mind that I don't know Bobcad, but in Solidworks you can create a sketch then go to save it using "save as" and rather than saving it as a part file (the normal default) save it as a dxf file.
    Most cad systems can open dxf files and you should have a file with the sketch as line graphics and any dimensions you have defined.
    Hopefully Bobcad can do the rest for you.
    Best Regards Sarah
    Jun 2008
    152
    Just click save as and select DXF. It will want to save it as a annotation but it still works.
    Forrest
    Aug 2014
    161
    Cool thanks, cause yeah when you open a standard part file that's a sketch it's blank.
    Dec 2011
    361
    Chevy,
    This is correct. In BobCAD, the only information we pull out of a .sldprt is the solid information. There are a few different methods that can be done to bring out the sketch, such as exporting the file as a DXF as Sarah recommended. You can also sketch inside a drawing and then export out the drawing as a dxf/dwg from within the SolidWorks drawing module.
    Oct 2010
    1189
    I use Eagle for pcb s but i draw In turbocad and use bobcad for cam for 3D i use iges Format in 2D dxf is ok i Hope that helps
    Gesendet von iPhone mit Tapatalk
    Aug 2014
    161
    Is eagle best suited for pcb? I'm already concerned about running an endmill on a single line and how to comp for it, do I need to draw everything in relation to the diameter of the end mill so that my wanted dimensions are correct? Or when I tell bobcad to comp left is it going to cut the outside like a normal 3d part would?
    Oct 2010
    1189
    hi chevydyl eagle workflow is draw the circuit in one pane you have a library of almost all parts and if not draw your own part. then you have 2 nd pane where the pcb layout is. then you arrange the pars on your pcb like in real world tell it if single sided pcb or double etc where the drills are shape of pcb ( this layer you can export in dxf for milling if nreded ) then you use pcb-gcode or similar script to produce your gcode i use a version which has autolevveling but that is another story if you do lets say an alu casing out of a block you would start from that dxf import i hope that clears the subject a little of course you can send your drawing or gerber export to an manufacturer
    Gesendet von iPad mit Tapatalk
    Aug 2014
    161
    Thanks for the help, it worked exactly as I needed it to.
    Oct 2010
    1189
    hi does it mean you followed my toolchain or some other solution ?
  1. negative of a solid in solid works
    By ringanator in forum Solidworks
    Last Post: 02-09-2015, 03:58 PM
  2. Replies: 0
    Last Post: 05-01-2013, 05:00 PM
  3. Replies: 4
    Last Post: 02-07-2012, 05:57 AM
  4. Solid Works 2010 2d sketch printing
    By chet470 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 05-02-2011, 08:57 PM
  5. Solid Works 2007 Question
    By SPEEDRE in forum Solidworks
    Last Post: 03-07-2011, 01:50 AM
