585,997 active members*
5,058 visitors online*
Results 1 to 7 of 7
    Dec 2015
    4
    PROBLEM laser stops work after an hour
    yesterday I was working with my laser machine, cutting some MDF 3mm to 90% power, when he started down the ammeter needle up to 19 m, when it stopped working, now you do not check anything from the ammeter and laser not turn on when I connect a multimeter to the anode and cathode of laser ammeter shows a good value
    the tube appears to have no water inside or be cracked
    Test button my source of power seems to be working well
    I hope you can help me, any suggestions ??
    Nov 2010
    787
    Re: PROBLEM laser stops work after an hour
    Quote Originally Posted by enteakbal View Post
    when I connect a multimeter to the anode and cathode of laser ammeter shows a good value?
    What do mean as good value? What did you measure?
    What do you mean: seems to be working well ??
    CNC lasers, constructions, service
    Dec 2015
    4
    good value i mean the ammeter i showing 19 ma or something like that and wen i conect the anode and catode to the tube the ammerteher shows 0a again
    the test butos of the power suply tunrn on a red light on the power suply
    i remove the tube and no cracks on it but the lasert still no work
    sorry for my bad english im mexican
    Nov 2010
    787
    Still do not understand. How can anmeter show anything when is disconected from laser kathode?
    If you connected anode (red wire) from PSU to laser and cathode from laser to anmeter and anmeter to Ground this should show what current flows through laser (tube).
    If there is 0mA that means:
    - PSU is faulty.
    or laser is faulty
    or connection is faulty
    or there is no WORK signal to PSU.
    Red light on PSU do not nean it is 100% working well.
    You may not use anmeter. Just connect black wire from laser (cathode) to Ground.
    To check PSU without laser have cathode wire from laser close to anode connector (around 2cm away) and push test button.
    Should be strong arc between so stay away.
    There is no way to check laser (tube) without other PSU.
    Dec 2015
    4
    Quote Originally Posted by cinematic2 View Post
    - PSU is faulty.
    or laser is faulty
    i check the psu without laser tube i put anode 2cm from catode a press the test button and nothing happens?? the power supply is broke??
    Nov 2010
    787
    Other end of cathode cable is connected to Ground?
    Looks so you need new PSU.
    Dec 2015
    4
    yes bro i change the bobine of my psu and the laser works thanks for the info
  1. 100W Reci laser tube dead after less than 1 hour
    By DarrylD in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-24-2016, 12:28 PM
  2. 100W Reci laser tube dead after less than 1 hour
    By DarrylD in forum Australia, New Zealand Club House
    Last Post: 10-22-2014, 12:59 PM
  3. Alibrie Licensing stops work
    By lkenney in forum Uncategorised CAD Discussion
    Last Post: 02-26-2012, 05:43 AM
  4. laser stops when doing large bitmap.
    By Robottawa in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-30-2009, 01:08 PM
  5. Laser stops moving and burning half way
    By CARTOGATE in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-28-2008, 03:46 PM
