I've tried to search around for quite a while now and I've been testing various things but I just can't find a simple solution to aligning sketches/bodies/components to other components/bodies.
In another CAM program I use at work for a laser engraving machine I can make a rectangle of 100mmx50mm, place a text inside this and then select both the rectangle and the text and hit a button to center the text in all directions or one button for X and one for Y.I guess I won't find a solution that simple in Fusion 360 since it's not made for this but there has to be some kind of solution to centering text when engraving like this?
I've tried to make a simple drawing of my exact problem below here. I want to center the text in X-axis compared to the rectangle I've placed the text on. I can eyeball this but I don't like to work that way.
---Name 1---------------------------
------Name 2 -----------------------
----------------------Name3---------
