Review – Shenhui SH-350 Laser engraving/cutting machine (Chinese E-bay laser cutter 300mm X 500mm)
Shenhui lasers became quite popular recently among hobbyists and enthusiasts because of their low cost (around $1550) and availability on the US market. Unlike many other Chinese brands, Shenhui lasers are stocked in California and shipped fast with domestic couriers. Receiving the machine usually takes about a week and the shipping cost is only a small fraction of what you have to pay for oversee shipment. As far as I know the couriers vary – mine was shipped via Fedex. Another aspect that makes these machines attractive to enthusiasts is that they are relatively easy to support, maintain and modify.
1. Ordering from E-bay and shipping
The ordering process was straight-forward, I received a couple of emails from the seller with shipping information. The seller's English was worse than mine (not a first language for me), there was some confusion with the shipment information. The seller provided wrong phone and address information to the courier and wrong courier company info to me. I would suggest to take these things in your hands and double-check everything with the courier yourself.
2. Packaging
The laser machine came in a rough plywood crate with some basic foam sheets inside. Overall the packaging is good enough and there shouldn't be any damage if the crate is handled the usual way.
3. Housing
The entire housing is made from steel sheet-metal which makes the machine heavy and solid. All the panels had scratches and hit marks. They are manufactured with the loosest tolerances I've seen. All the covers and hinges fill loose and make rattling noises when the machine operates. The locks used for securing the covers in closed position are super cheap and flimsy. The whole machine was quite dirty as well. The top canopy has a transparent window made probably from acrylic. The doors and the removable covers allow for easy access to practically every part of the machine. There is also plenty of space for modifications.
4. Safety
The laser tube is covered with a long lid without a safety switch - If a user opens the lid accidentally while the laser is on he/she will be exposed to the laser radiation, so be extra careful! Because of the poor quality of sheet-metal work on the housing, the radiation from the tube is reflected or exiting directly through several openings. You should always wear protective glasses around this machine. They are not provided in the package, you need to buy them separately. The transparent window on the top doesn't have a protective film or coating therefore it is unsafe to look trough it without protective glasses. The work bed is made from highly reflective steel plate which makes the situation with the reflected radiation even worse.
5. Standard features and accessories
- Laser tube - Cheap Chinese tube that doesn't perform as per specifications. The tube is specified as a 50W but reaches its maximum performance at about 65%. The actual performance is similar to the 35W higher end tubes.
- Drive system - The machine uses very cheap guide rails, belts and steeper motors. I am not an expert but I wouldn't be surprised if these components are among the cheapest on the Asian market. The drive system runs stable and relatively accurate at speeds up to 20mm/s. Any other speed above that mark will produce jaggy curves which became worse at the higher speeds. The maximum speed on the X (long) axis is 500mm/s and 400mm/s on the Y (short) axis. The low precision of the drive system is not going to be a problem when cutting/engraving wood but it will cause issues if you try to cut/engrave fine intricate designs especially at high speeds. When engraving acrylic even at the lowest speeds you will be able to see the fine vertical and horizontal steps. When cutting acrylic you will never have perfect clean “vector” curves. The micro steps are not horrible but are easy to see when you look close. If you try to cut fine details in paper you will have to run the machine at 20mm/s which would also mean burned edges and smoky parts. Overall it works fine and you wont be disappointed as long you don't expect the performance of the top-in-class laser machines.
- Work bed - It provides a manual vertical adjustment for working on deep objects. The size is significantly larger than than the actual operation limits. The bed travels on 4 long vertical screws synchronized and driven by a belt. The screws are securely assembled at the base but very loose at the top which makes the whole tray to shake and vibrate wen the machine is working. This makes the problem with the jaggy cut lines even worse. The tray (bed) itself is made by a sheetmetal frame and removable perforated sheet over it. The top sheet is highly reflective and the perforations are insufficient for proper ventilation which makes the default work bed pretty much unusable in most scenarios. Fortunately the top sheet is attached with screws and is easy to be replaced.
- Ventilation - The machine has a 6” duct at the center of the back panel, below the work bed. It is equipped with a relatively quiet fan that moves some air but to achieve better suction of smoke and fumes it is highly recommended to be upgraded with a bigger blower.
- Light - It comes with a long fluorescent light without a shader on the top so glare could be an issue for some people.
- Rotary attachment - It comes with a basic rotary attachment for engraving cylindrical objects. I haven't tried it yet.
- Laser cooling - The laser is water cooled. The package comes with a small water pump that should be placed inside a container filled with (purified) water and connected with hoses (provided) to the machine. The pump is very quiet when is under water. I can not say anything about the performance as the machine doesn't have temperature indicators.
- Laser head and lens - The head is well made and it comes with a standard 20mm diameter, 2” focal length lens. The lens can be accessed, replaced and cleaned relatively easy. In general it is highly recommended to clean the lens frequently.
- Air assist - The machine comes with a small external air compressor that blows air trough the laser head and moves the smoke from the cutting area. It looks very cheap, runs hot and it is noisy.
- Infrared pointer - Very inaccurate. I tried hard to align it but I was unable to point it exactly over the cutting beam.
- Built-in computer - The machine comes with one of the best Chinese controllers, with a small color LCD display and a basic keyboard on the control panel. The built-in computer allows the machine to read and display files from a USB Flash Drive directly without an external PC.
- USB connection to an external computer - The machine can be controlled very easy with a Windows based computer using free RDWorks software.
- Network connectivity - LAN port allows the machine to be easy connected to an ethernet router and accessed from multiple remote computers. You don't have to use the port on the side of the machine. the cable can be routed under the machine and plugged directly to the controller.
- Software - The RDWorks software is probably the most popular Chinese cutting/engraving control software. It is old and unintuitive but it is quite basic and easy to learn. It supports importing from some really old versions of CorelDraw and AutoCAD via plugins, but could also import directly Adobe Illustrator V.8 files and Inkscape (free software) DXF files.
6. Calibration
- Mirrors - The mirrors on my machine came well aligned so I didn't have to do that myself. The alignment is controlled with simple thumbs screws. There are some instruction in the machine manual as well as some online videos showing how to do this.
- Work bed flatness - The work bed belt can be un-tightened with a single screw, then each of the 4 long vertical screws can be adjusted to achieve a perfectly flat bed. The flatness of the bed is essential for the quality of the cutting/engraving.
- Infrared pointer - Can be adjusted in 2 axis and tighten in position with a single screw.
- Step size - My machine had a serious deviation between the part sizes in the digital files and the cut parts. At the maximum length at the X and Y axis the deviation was around 2mm! This can be corrected very easy in the “vendor settings” inside RDWorks software. To access the vendor parameters you need to type a password: rd8888
- Focal point - The machine comes with a simple rectangular piece of acrylic to measure the distance from the material surface to the laser head. The focal distance from machine to machine will vary a little and it is recommended to check it. There are some online videos showing how to do that.
7. Optional items, upgrades and modifications
- Safety glasses - The laser radiation, direct or reflected, is very dangerous for your eyes! Get a good brand glasses! this is what I got: LS-CD2-OTG CO2/Eximer Laser Safety Glasses Model OTG
- Stand - when the machine operates at high speeds it shakes quite a bit affecting the quality of the results. Initially I tried to use it on a heavy kitchen table but it was vibrating a lot. If you make some custom stand yourself make sure it is massive and rigid. I ended up buying 2 aluminum work platforms on sale for $19 each. They fit the machine size perfectly and are very stable! Here is the exact model: GLA-47WP
- Higher capacity blower - I got iPower 6-inch INLINE DUCT FAN blower 430 CFM. I feel this is the right performance blower for this machine. It provides excellent suction and it is reasonably quiet.
- Ammeter - It is highly recommended to add ta 0-30mA current analog meter to monitor the power going to the laser tube. The settings in the control software provide a universal range for different models and will not match the actual performance of your laser tube. The safe range for these machines is around 5%-65% but is best to measure it with ammeter. If you overpower the tube you will shorten its life or burn it. There is a lot of information about this upgrade online.
- Work bed upgrade - Most laser cutters/engravers come with honey comb tables for less reflection and better ventilation. Similar or better results can be achieved with a custom pin table. There is a lot of info about that online.
- Different focal length lens - The laser head supports standard 20mm 2”FL lenses. I haven't tried it myself but an upgrade should be possible. There are several available options between 1.5” - 4” focal length. The general rule is: shorter focal length will make the laser beam thinner and precise, but also shorter therefore for cutting thicker materials longer focal lengths are used.
- Fume extractor / air filter - If you have to install the machine in a closed area you will need to filter the smoke/fumes. For light use you could use standard 6” duct carbon filter and in-line filter boxes. For heavy use a professional grade fume extractor would be necessary.
- Better compressor - There are a lot of small air-brush compressors. Some of them are very quiet and will have the right performance.
- Closed water container - Most people will simply use a plastic bucket, but any plastic container with a lid/cover would keep the water cleaner. Just drill few holes on the top cover for the hoses and the power cable of the water pump.
- Chiller - If you intend to use the laser at max power or for long work cycles the default cooling may not be sufficient. The 110V CW-3000DF chillers are somewhat standard for these size machines.
- Digital thermometer - A small digital thermometer with a probe can be set to measure the temperature of the water exiting the laser tube. Overheating the laser will shorten its life or burn it.
- USB camera - There are some very inexpensive probe digital cameras with long USB cables. If your computer is close to your laser machine you may attach one to the laser head and to your PC.
- WiFi - I haven't tried that myself but there are a lot of very inexpensive LAN to WiFi adapters that will make the machine accessible over your WiFi network.
- Metal rulers for the work bed - One L-square for the top left corner of the work bed and one vertical for measuring the vertical travel.
- Custom fittings for the work bed vertical adjustment screws - Custom fittings can be cut from acrylic to fit perfectly the top support brackets to eliminate the wobble and vibrations of the work bed.
- Sealing the laser tube compartment - A standard weather seal adhesive tape could be used to seal the laser tube box and contain the radiation better.
