585,975 active members*
4,865 visitors online*
IndustryArena Forum > Maintenance in General > Maintenance DIY Discussion > Axis limit blocked axis movemnt on Mikron WF40C
    Jul 2014
    221
    hi there, does anyone have experience with that machine, we've just got it and don't yet know it's quirks and tricks.
    We were trying all axis motion from end to end and the Z- movement hit hardvare switch (endswitch) which blocks all axis movements according to manual.
    Seems like this machine has two axis limiters, one is software, value in um (micrometers) set in machine parameters which when you reach, the alarm will notify you and stop the axial movement, but you will be able to manually retract the axis back from this software limiter and reset the alarm - no worries.
    The problem is that on one axis, Z, there was no software limit, it was set basically as 9999999 or like 10 meters but the machine only has something like 700 milimeters or 0.7 meters in travel on that axis.
    So now all axes movement is disabled and we can't use machine until it's somehow moved away from that switch or reset.
    We don't know how and we can't change the value in machine parameters (parameters number 160-163 and 170-173). What's the procedure or syntaks to change those parameters?
    There is supposed to be a manual/auto switch inside the machine control (behind the monitor and keyboard external unit) which we've pressed but nothing happened, still couldn't move no axis.
    I don't know if we should'he tried turning machine off first then flipping that switch and then turning it back on, because we tried it while it was running - no effect.
    Please help because we need the machine and the service is far away from us so if we call it even for such a simple fix it will be expensive.
    Jul 2014
    221
    Re: Axis limit blocked axis movemnt on Mikron WF40C
    guys heres the update to the case.
    I've removed backplate from control unit and seen two switches which I thought might be for manual control of the axis movement.
    heres one:
    http://i65.tinypic.com/sc6sft.jpg
    and the other
    http://i65.tinypic.com/1o22s9.jpg
    none of them worked in any combination. there was no change, error no 1 still blinking.
    Then I've removed sheet metal on left side of table where the limit switch was activated and loosen it,
    still no change even if it was deactivated.
    here's the picture:
    http://i64.tinypic.com/213554y.jpg
    On the right side of machine I've found another switch which I don't know what it's used for, but I've found only one, unlike on the left side, where there's two one for z+ and other for z-.
    So on the right side there appears to be only z+ switch, extremely low under the table,
    here it is:
    http://i68.tinypic.com/219wgn4.jpg
    I don't know if there is another switch like that for z- on the right side, I've looked all the places it coul and should be and still couldn't find any hint of it.
    What else could be wrong that the machine won't move even if I removed the activated limit switch on left side(third pic)?
    Jul 2014
    221
    the limit switch was stuck from lack of use and after I worked it out, it unstuck the machine, i was able to manually move the machine back by hand tool, away from limit switch.
  1. Relative position on mikron 5 axis 1350u
    By Rmc78 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-02-2014, 04:09 PM
  2. X-axis motor doesn't turn, it's blocked all the time - how can I fix that?
    By Klausb in forum Machines running Mach Software
    Last Post: 05-13-2013, 09:05 AM
  3. Over Axis limit
    By eckolaw in forum Bridgeport / Hardinge Mills
    Last Post: 12-11-2008, 02:30 AM
  4. B-axis limit on Fadal
    By 5th-axis in forum Fadal
    Last Post: 12-06-2007, 11:25 PM
  5. Limit switches for XYZ axis
    By scheek in forum CNC Machine Related Electronics
    Last Post: 09-07-2006, 01:33 PM
