Hello, I am new here and have one bad problem with this milling machine. Controler is OSP-U100L, connected to server pc with ethernet cable, running DNC. Everything worked well for several years. One day suddenly machine crashes during milling, OK, maybe error in some offset, checked.
Seems OK. Start again, few hours later alarm 2206 Alarm B :Expression syntax 5. There was one - sign added to sixth line of program. Checked program at server, everything OK. Next day, new day, new alarm 2215 Alarm B: Program bad direct:numerical data 2. No clue.
Third day stops again, two dot sign added to program line Z25..254. And so on. Checked ethernet cables, switches, new cable, connection directly to server without switches, same thing. Called Okuma service, they send a service man, says that the HHD raid is bad, red led blinking. Replace failed disk, no red led, same situation on machine, randomly add - or . or G sign to program line.
Okuma replaced TCP/IP board. Same problem. Replaced SCSI card for HDD, same problem. Sometimes misplace a dot in the number for example instead of Z 23.245 wrote Z234.45 with , cause error. I am lost. What else we can exchange?
Regards
