Hello every body
i m new in cnc routers i have a driver for nema 34 round 8 wires with CP Dir En Res and +5v
how can i hook up these
bundle of thanks for advance
Hello every body
You have listed the drivers inputs not outputs, the outputs are often labbelled a- a+ b- b+.
If it does just have 4 output terminals you need to pair of the 8 wires into 4. To pair them you need the motors pin out diagram.
I have 2 drivers with names A and B in A Driver their are following Signals CP Dir EN Res +5v NC Nc and Motor Out Puts are A+ A- Grnd B+ B-
and driver B their are following Signals CP Dir NC En +5v NC NC and motor out puts are A+ A- Grnd B+ B-. I hook up driver B with following settings CP and +5v to Mach3 Break out Boards +5v and En to X Pul and Dir to X Dir with these settings the driver runs great but Driver B did not run it accecpts power and noise of signals when i command it through Mach3 but it did not move motor so where the problem and how i hookup the driver A
its work dear its work thank you so much you done it
