585,712 active members*
4,279 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > 18i hidden parameter view/change?
Results 1 to 7 of 7
    Nov 2006
    Dose any one know how to view/change the hidden parameters on a 18i controller?
    TIA
    John
    May 2006
    82
    On the 15i I run there are two places to see and change parameter settings. One is on the "Offset" button and the other is with the "System" button. The "System" button will show all parameters that are paid for.
    Dec 2006
    5
    There aren't hidden PArameters on Fanuc CNC if you want change parameter you must put the cnc in MDI mode after push the Offset button and change PWE from 0 to 1 now you can change the parameter value. After remember to put the value of PWE to 0.
    Bye Andrea.
    Nov 2006
    got it
    Dec 2006
    22
    Exclamation YES there are hidden parameters
    all the system parameters are hidden #1000 to #1100 you can not see them, but if you wanna see the value of system parameter then there is other way for ex. say you wanna see what #1000 parameter value is
    you can make a small program goes like this
    #100=#1000
    then check the #100 that way you can find the value of #1000 parameter
    its 21it control
    Nov 2004
    53
    Er, those are variables not parameters
    Happy Holidays
    May 2006
    265
    The variable will have the same value as the parameter, then you can se what you got...
