585,938 active members*
3,393 visitors online*
    Nov 2015
    25
    My limit switch solution for the 6040 cnc router
    Here is my solution for adding limit switches to my 6040 router
    The advantage is that I can tune the position where it kicks in. No special tools required other than a cheap ALDI threading kit.
    Apr 2013
    1899
    Re: My limit switch solution for the 6040 cnc router
    Nice pictures. Why do you think you need to tune the limit switch? I mean, once it is set up I don't see any needs to change the limit switch position.
    Nov 2015
    25
    Yep, I guess so.
    I'm not that great at getting the holes in the right spot, so it is good to be able to adjust
    Apr 2013
    1899
    Quote Originally Posted by titantomorrow View Post
    Yep, I guess so.
    Oh, I see... That's what you meant by "tuning the limit switches" Of course, even my limit switches need initial adjustments and setup, but once that is done it will stay like that forever.
    Jun 2004
    6618
    It is a nice feature to be able to adjust the limits when you have a slave axis. Then you could easily square the gantry when you home the machine by adjusting just one switch.
    Were there a few choice words when you installed the switch in that last picture?
    Looks great BTW.
    Lee
  1. Digital Tool Meta DR-904 Router Retrofit Limit switch questions...
    By NORTHSTARTIM in forum Commercial CNC Wood Routers
    Last Post: 08-27-2014, 07:15 PM
  2. limit switch on z axis of 1325cnc router
    By toukas in forum Uncategorised WoodWorking Machines
    Last Post: 01-05-2014, 04:32 PM
  3. Soft/limit switch - 5 axis Router
    By Barakathz in forum Mach Software (ArtSoft software)
    Last Post: 09-12-2011, 09:23 PM
  4. Replies: 2
    Last Post: 08-15-2007, 02:32 PM
