585,956 active members*
4,632 visitors online*
Thread: PWM circuits
    Jan 2009
    32
    PWM circuits
    Does anyone have an idea how to make a circuit between the two devices as in the picture?
    I have a PWM source which operates from 0 -2.5-5v and analog devices to the entrance between the input and GND has 5V and then output either 10V when you connect a short input and GNG have + 10v
    2.5v = 0V
    at the exit of how to do to merge these two assembly
    greeting
    Mar 2006
    202
    Re: PWM circuits
    Some filtering turns the PWM into an analog value. Then one (or a few) op-amps can amplify, invert and offset the 0 to 5 volts to 10 to -10 volts.
    The trick though is getting a sensible output when the input is not running. If the PWM is off, what should the output voltage be, considering safe operation?
    Feb 2007
    966
    Re: PWM circuits
    Yes , you can use a simple RC filer on the pwm then a differential opamp to offset and double the voltage
    Quote Originally Posted by vegipete View Post
    You have the PIC output a delayed enable to the amplifier to only turn it on when its stable. Thats what i do on my step2linear
    Aug 2019
    In addition to monitoring the output state of the power circuit, PWM (Pulse Width Modulation) circuit also provides power component control signals, so it is widely used in various high-power circuits such as switching power, motor Inverter, audio for V D-polar amplifier, DC-DC converter, and UPS.
  1. deciding how to power circuits
    By Goosey in forum CNC Machine Related Electronics
    Last Post: 11-01-2012, 10:45 PM
  2. Practical Interface Circuits
    By striplar in forum CNC Machine Related Electronics
    Last Post: 03-28-2009, 12:06 AM
  3. How do I construct these circuits
    By FeldWill in forum CNC Machine Related Electronics
    Last Post: 03-03-2009, 04:02 AM
  4. Voltage Foldback Circuits
    By tahoka in forum CNC Machine Related Electronics
    Last Post: 02-16-2009, 03:01 PM
  5. Found some steppers circuits
    By xairflyer in forum CNC Machine Related Electronics
    Last Post: 11-08-2003, 06:19 PM
