Hello folks,
I'm working on getting my little benchtop G0704 Conversion home machine up and running at any sort of a workable workflow right now for use with my TTS tooling, and I have three problems. The post is a MPMaster edit, here's an example of how it tool changes currently
Code:
M5
G49 G0 Z0. <---- This sends my spindle into the table
X0. Y0. <---- Manual tool changing, not necessary
A0. <---- Completely unnecessary
M01
G49 T2 M6
etc.
I would like to change the post to remove the unnecessary moves, as well as remove the G49 and replace it with G28, so that it just sends it to Z home for the tool change. I've poked around in the post but I cant seem to get it right, care to give me some advice on where the right variables are? I recognize that I will probably have to configure it to post something along the lines of
Code:
M5
M01
G91 G28 Z0.
G00 G17 G20 G40 G80 G90 G54
G49 T2 M6
etc.
I pulled the [G00 G17..] string from the output of a VF2 post here at work, if that's a mess to implement/not really necessary its not a huge loss, just a good safety line.
Attached is the post if it helps.
