585,894 active members*
5,184 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Drawing wood bowel
Results 1 to 12 of 12
    Apr 2011
    68
    Drawing wood bowel
    Have v25 3 axis , I would like to draw a 3d wood bowel , 8" dia by 8" depth tapered , I am going to make a dropdown pocket in my cnc wood router table. So I can have enough Z cutting area , any help would be appreciated .
    Ed
    Jun 2008
    1838
    Re: Drawing wood bowel
    As you didn`t give any angle for the taper or wall thickness I just made it up
    Try the attached file.
    P.S. This was done with V25 Build 895
    Regards
    Rob
    :rainfro: :rainfro: :rainfro:
    Jun 2008
    1838
    BTW Forgot to mention, it was done in a few minutes using just Primitive Solids, made a couple of cones and Booleaned one from the other
    Dec 2013
    290
    I would use a revolve for a bowl.
    1 sketch, and done.
    Work: Hurco VMX42/VMX50 - Shopsabre 4896 - Bobcad V4 4axis pro
    Home: RF45 with Ajax CNC Controller - Bobcad V27 3 axis pro
    Apr 2011
    68
    Thanks , I can't get the file to open though , but I appreciate it.
    Ed
    Jun 2008
    1838
    Quote Originally Posted by edcross View Post
    Ed
    What is the build number of your V25, if it is older than Build 895 then it will not open the file, I assume you are able to open the Zip file OK ? ?
    Attachment 303810
    Anyway, here is another bowl done in an older version V24, if you have V25 then you should have no problem opening the file
    Attachment 303812
    Hope this works for you now
    Regards
    Rob
    Apr 2011
    68
    I have Build 996 , but it would not load it , but this new one viola , thank you .
    Ed
    Jun 2008
    1838
    Ed
    OK, that`s good, all you have to do now is machine it
    Strange the other one didn`t open
    Regards
    Rob
    Apr 2011
    68
    Hi Al , I now have V 29 . I want to cut a bowl 12" dia x 4" high with radius sides , I want to draw and cut inside and outside . Can you point me in the right direction , are there any videos etc.
    Thanks Ed
    Jun 2008
    1838
    Ed
    One way to do it using simple Solids, quick and easy :-
    Draw lines and arcs to get the correct arc radius for the outside shape.
    Next, create a solid Sphere using the radius you got (In your 12" x 4" bowl would be a Rad of 6.5") and set it at X0,Y0,Z6.5 so the bottom of the Sphere is at Z0.
    Next, create a Circular Plane that is a little bigger than your Sphere and place it at X0,Y0,Z4"
    Next use the "Split Solid tool and cut the Sphere at that height so that will give you your 4" height, now delete both the top part of the Sphere and also the Circular plane and you will be left with a solid the shape of your bowl.
    Next use the "Shell" option to set your wall thickness and create the internal shape, assuming that you want a parallel wall thickness.
    I have attached a sample file for you, done in V28 so you should be able to open it OK, I did the wall thickness at 0.25" but you can easily edit that in the CAD Tree,
    There are other ways but I think this is the easiest
    Regards
    Rob
    Attached Files Attached Files
    Jun 2008
    1838
    Ed
    Another way to do it is to draw the shape of half the cross section (a quadrant) and then use the "Revolve" strategy to create your solid shape. You have to do this so it is drawn in the X axis otherwise it doesn`t revolve correctly.
    Next you need to Rotate the solid so it is the right way up and then do the "Shell" operation, this is another easy way.
    Or, you can just draw the shape you want the bowl to be with the wall thickness you want and then just "Revolve" it, no "Shell" required, even easier
    File attached.
    Regards
    Rob
    Apr 2011
    68
    Thank you.
    Ed
  1. new drawing board --wicked size 44x60 drawing area
    By woodman08 in forum Logic Trace CNC/DXF
    Last Post: 02-08-2015, 12:58 AM
  2. Replies: 0
    Last Post: 07-21-2012, 03:14 AM
  3. tired a wood called bow wood or orange osage
    By woodman08 in forum Gorilla CNC Machines
    Last Post: 01-17-2010, 03:37 PM
  4. Replies: 13
    Last Post: 10-02-2009, 04:32 AM
  5. converting imported part drawing to mold drawing
    By msomerville in forum BobCad-Cam
    Last Post: 08-29-2008, 12:56 PM
