585,764 active members*
4,076 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > CITIZEN Machines > Citizen L20 - 'Pneumatic System Pressure'
    Jan 2016
    Angry Citizen L20 - 'Pneumatic System Pressure'
    Hi guys,
    We've a Citizen L20 and we keep getting constant alarms for 'Pneumatic System Pressure'. Has anyone encountered this before and can shine any light on this problem? The machine runs OK for a while and then stops mid-cycle. The times between it starting and the alarm vary from minutes to hours. We have another 20 machines in the factory that are all working fine so it isn't an issue with the air getting to the machine in the first place...
    Hopefully someone on here can help with the issue!
    Thank you,
    Ben
    Sep 2011
    261
    Re: Citizen L20 - 'Pneumatic System Pressure'
    If its only that machine having the issue, I assume your pressure sensor is going bad.
    Or, is the machine at the very end of an airline? it could be starved if so
    CNC Product Manager / Training Consultant
    May 2011
    6
    I had this same problem a cpule of months ago. Had to change the filter in the seperator directly in front of the pressure sensor on the back of the machine
    Feb 2019
    14
    Hello.. We are looking for parameters of Citizen L20 5-axis CNC Swiss Sliding Head Machine with Mitsubishi Medlas 300 control from 1997.
    Let me know if anyone could provide us with it.. Thanks Regards
  1. Incessant Pneumatic Pressure Alarms on Citizen A20
    By PoiToi in forum CNC Swiss Screw Machines
    Last Post: 05-15-2016, 06:04 AM
  2. High Pressure system veterans
    By SirDenisNayland in forum CNC Swiss Screw Machines
    Last Post: 11-12-2011, 06:05 AM
  3. Citizen F20 Over-Sized Collet System?
    By yoopertool in forum CNC Swiss Screw Machines
    Last Post: 01-24-2010, 08:37 PM
  4. CITIZEN E-serie (MITSUBISHI system)
    By subalb in forum CNC Swiss Screw Machines
    Last Post: 01-22-2008, 04:16 PM
  5. DIY coolant system with loc-line - how much pressure?
    By Eddiep in forum Benchtop Machines
    Last Post: 09-07-2007, 09:13 PM
