584,874 active members*
5,120 visitors online*
IndustryArena Forum > CAM Software > SprutCAM > sprutcam 9 tool library issue, waterline issue, was working fine
    Nov 2012
    104
    when i go to library to select a tool, seems to be defaulting on tool 2, when i pick another tool it cell N stays stuck at tool 2 if its a new operation or whatever tool it was already set to if its an existing operation. i have to manually change the tool number in cell N.
    i also noticed i can no longer sort the rows by tool number by picking the top column header.
    my rough water isnt working at all AND my finish waterline isnt working like its suppose to. it was all just working fine 5 minutes ago.
    any ideas?
    thanks
    Carlos
    TPR Motorsports
    Nov 2012
    104
    Re: sprutcam 9 tool library issue, waterline issue, was working fine
    nevermind, i must have somehow fat fingered the use tool number box, i checked it and the sorting and tool number issue is fixed.
    my waterline isues is from the model, somehow the surface is not flat.
    Carlos
    TPR Motorsports
  1. SprutCAM Tool Library tool numbers
    By MichaelHenry in forum SprutCAM
    Last Post: 06-29-2016, 02:30 PM
  2. Turret tool library for SprutCAM
    By MichaelHenry in forum Tormach Slant Lathe
    Last Post: 12-08-2015, 12:40 AM
  3. Tormach and SprutCAM issue
    By kevinro in forum Tormach Personal CNC Mill
    Last Post: 01-29-2012, 05:36 PM
  4. SprutCAM / MACH3 tool library conversion utilities
    By cgroves in forum Tormach Personal CNC Mill
    Last Post: 09-05-2010, 10:49 PM
  5. SprutCAM 7 Milling Issue
    By Pat_IS in forum SprutCAM
    Last Post: 07-16-2010, 01:00 AM
