585,982 active members*
4,669 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Heidenheim TNC 145 question about driving voltage (retrofit and driving voltage)
    Question Heidenheim TNC 145 question about driving voltage (retrofit and driving voltage)
    Hey all together
    Has anybody any experience with retrofiting a cnc machine ? I would just like to know does the TNC 145 from haidenheim use +/-10 V Analogue for driving the motors? The motor driver and wiring is in the link below.
    I woudl use the CSMIO/IP-A.
    http://www.dropbox.com/sh/4yh9wlognl...VMW-oOmxa?dl=0
    Thanks in advance.
    gizmoo333
    1121
    Re: Heidenheim TNC 145 question about driving voltage (retrofit and driving voltage)
    yes 10v
    I don't know that machine, but the servo amps are half the problem on other machines as far as performance is concerned so I would swap those also
  1. Help..Stuck at relay ext dc voltage missing but dc voltage OK ?
    By Dirky in forum Bridgeport / Hardinge Mills
    Last Post: 05-14-2021, 06:39 PM
  2. Chopper drive max voltage vs max voltage of Nema23
    By K_G_B in forum Stepper Motors / Drives
    Last Post: 07-11-2014, 04:17 AM
  3. High voltage power supply, low voltage perihperals
    By feechl in forum CNC Machine Related Electronics
    Last Post: 01-07-2014, 02:12 AM
  4. Precix 9100 Controller - VI voltage issue Voltage range only 6.5 to 10Volts
    By wdysf150 in forum Controller & Computer Solutions
    Last Post: 08-15-2013, 08:24 PM
