585,898 active members*
5,267 visitors online*
IndustryArena Forum > CAM Software > CamWorks > Camworks in Solidworks assembly mode - cannot access camworks features
    Jul 2013
    51
    Hello
    I've been using Camworks for well over a year now and have a general grasp on the basics, however one thing I cannot work out what is happening is when I open a Solidworks assembly, Camworks will not allow me to add toolpaths.
    In the past as a workaround I've saved the assembly as a part and then added the toolpaths to the part. The problem then is when I make a minor change to one of the part files in the assembly, it creates a hours work work creating a new part for the toolpaths and having to redo every single toolpath for the new file as opposed to a few minutes work if the toolpaths were on the assembly file.
    In camworks, the first lot of icons are all dissabled up until "new 2.5 axis mill" - I can click on this and select "rough mill", however when I click new I cannot add anything after that. It's simply not working.
    In the drop down camworks manager menu's, there are no options to actually add stock or add a mill part setup. It's just not there.
    Anyone else have this trouble and find a solution?
    Thank you.
    Jul 2013
    51
    Re: Camworks in Solidworks assembly mode - cannot access camworks features
    I've actually just found where I was going wrong, so if anyone else is struggling with this, here is the solution:
    https://www.youtube.com/watch?v=VC7l-IyRNyo
    Nov 2008
    10
    You just need to save your assembly as a part (*.sldprt) in order to add operations and tool[paths in Camworks. Yes, it's a pain, and yes, it causes extra files but that's how it's always worked for me.
    Dec 2010
    126
    No no no...the video demonx posted explains how to use assembly mode the proper way. If you're not familiar with it, you should learn it. It has a HUGE number of benefits.
  1. Camworks Wrapped Features
    By theestimator in forum CamWorks
    Last Post: 04-16-2014, 05:01 PM
  2. Camworks and Solidworks
    By rrbmachining in forum CamWorks
    Last Post: 11-04-2009, 04:31 AM
  3. Assembly in CamWorks 2007
    By fakeru in forum CamWorks
    Last Post: 07-10-2009, 12:45 AM
  4. CamWorks Assembly
    By pnance in forum CamWorks
    Last Post: 01-16-2007, 06:33 PM
  5. Camworks in Solidworks
    By CRPDGAZ in forum Solidworks
    Last Post: 11-10-2003, 08:53 AM
