Originally Posted by
mactec54
You obviously have never had any experience with these Chinese machines, if you Torque the cap-screws to the correct torque requirements, two things are likely to happen either the cap-screw will break, or you will strip the thread this is pretty much the norm, if you replace the cap-screws with a quality brand, this will only help if they have good threads to screw into, the best is to replace the Cap-screws use a little Blue Loctite and do them up tight without pulling the threads out, before using the loctite clean the threads of any oil or chips
