585,978 active members*
4,287 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > Fusion 360 post processing
Page 1 of 4 123
Results 1 to 20 of 66
    May 2009
    327
    Is everybody using fusion 360 using the mach3 post processor? Did you have to edit it at all? Going to try my first cam through it this week and trying to get all my ducks in a row...
    Thanks - Keith
    Aug 2007
    359
    Re: Fusion 360 post processing
    I have, but there's a G28(IIRC) line in there that messes things up. I've just been putting a "%" in front of the line and it works fine after that. Seems there was one at the end that caused me some grief too. I don't know how to edit the post processor to make it stop doing that.
    Don't have to be too bright to be me
    Jun 2004
    6618
    I only machine one part so far with Fusion, but it is about to become many many more.
    I just used the standard Mach 3 post and there are things that I do not like about it, but I will get by I think.
    To start with you MUST HOME the machine. Otherwise it screws something up with the offsets.
    I did notice that there is a CNC Router Parts post in there now. Not sure how this one differs from the run of the mill (punny?) Mach 3 post.
    I am designing several things in Fusion now that will need machining on both the CRP router and the Pulsar. Oh and the Tormach lathe too, but Adam has been creating a great post for it.
    Lee
    Aug 2007
    359
    Lee.....when you say that you must home it, are you referring to the G28(return to reference position) or just simply doing a ref all before starting?
    Jun 2004
    6618
    Ref all Home before you start the Gcode. We don't usually bother refing the machine home. It still retains X and Y axis positions from the day before if we don't. Then just a matter of setting Z with the master tool and hit Cycle Start.
    Don't try that with any code from Fusion or you will see some NovaKONFusion.
    Lee
    Jun 2004
    6618
    I also like to set my tool change positions for different jobs. Depending on the part and the job, that is better left up to me than the CAM software. Since I do not have an automatic tool changer, it should be my choice of where to park it to change the tool. I am only asking for a dialogue box and a line or two in the Post.
    I could not get those guys over there to see that my way, so I place my TCP code in there myself, nenner nenner.
    Lee
    Sep 2009
    1856
    not surprised there lee, my post I had to go on on and on at them to do what I need, it still has problems what they won't fix, the same as you, when it is tool change time it stops, I move it to where I can get at the spindle, change tool, set hight, hit start it goes to where it stopped, then goes to the next start spot, it realy anoying have the machine go from one end of the table to the other then it comes back
    http://danielscnc.webs.com/
    being disabled is not a hindrance it gives you attitude
    [SIGPIC][/SIGPIC]
    Jun 2004
    6618
    Right. Some of my tools are long drill bits.
    I run two double vises, so the bed is pretty much loaded with parts locked in place. You can't just change a tool like that just anywhere. It has been awhile since I let it run normal, but it still acts oddly. I suggest when you first try it out, put you most expensive..........least expensive tool holder in there with no tool in it until you see the motion.
    Never start a spindle without a tool holder in the collet and don't ask me just how I know that.
    Lee
    Sep 2009
    1856
    not sure what you mean lee, it's a big router I am not tall enough to reach over to the middle of the table, I would like it to move to a predetermined position but it does not, I tried to get that set but no one would do and I don't know how to do it myself
    [SIGPIC][/SIGPIC]
    Jun 2004
    6618
    I haven't looked at the CNC Router Parts post yet, but it may do what you want.
    At the end of each process in the Gcode when you need to change a tool, delete the G28. That would take it back Home. Insert the X and Y position that you want and go there at feedrate. For instance on my router, my TCP is something like X14 Y3 Z3. So my line would look like G01 F25 X14 Y3 Z3.
    It might be better to place the Z3 on a line by itself first if you don not have safe Z enabled. So G00 Z3 is what that line would look like.
    Then go with the X and Y moves on the next line.
    Lee
    Aug 2007
    359
    Thanks for clarifying Lee!
    I was of the understanding that I needed to ref all every time I fire the machine up. Since I don't use the mill everyday, I've always ref'd it when I turn it on.
    In your last comment.....you told him to "Insert the X and Y position that you want and go there at feedrate." I'm curious why you say to do it at feedrate. I would have thought it a rapid move......but as a beginner, my assumptions seem to break things. lol
    Jun 2004
    6618
    I try not to test code at rapid rates. Slow and steady like the turtle until I know I haven't misplaced a dash or dot. Then I just change it to G00. F25 won't matter at that point, but that can be deleted too.
    Lee
    Sep 2009
    1856
    I should of been a bit more clearer this is the tool change output, it has a G28 at the start what is fine as home is usually at the same place as X and Y work Zero, the Machines is too big to use the home switches all the time.
    is it the G28 in red I should get rid of. going over same stuff just to be clear
    N25570 X-13.172 Y10.742 Z-12.064
    N25575 Y10.734 Z-11.965
    N25580 G0 Z10.
    N25590 G28 G91 Z0.
    N25595 G90
    N30 M5
    N35 M9
    N40 T2 M6
    N45 S21000 M3
    N50 G54
    N55 M9
    what happens as you can see in the code it stops goes to Z machine zero, then I move it so I can get at the spindle, change tool, set tool hight, hit run with the spindle starting as well, it goes back to where it first stopped, then onto the next starting position. I still can't find why it goes back to the position where it stopped before going to the next cutting position this is one thing I want to get stopped, with the Vectric post it does not do this silly move at all I will have a look at that over post you said about.
    some of the people on the HSM forum are no it all's and won't do what you asked to be done at if they don't like that idea, that includes the resellers and staff, they like to stay in the nice safe box and don't want to try new things unless it comes from ADSK.
    just like the wrapping function fusion has now ADSK don't want anything to do with it at all, the people who commented on my requisition ever said it could not be done or weight to 4th and 5th axis continuous is finished, well Mark proved them wrong and it works fine.
    [SIGPIC][/SIGPIC]
    Sep 2009
    1856
    lee the CNC Router Parts post you can turn G28 off it does a G0 Z10 it moved to X0 Y5 Z5 for tool change ( I did not set this) then goes back to the last line before the G0 Z10 after you hit start then to the next start position so it's still doing a wasteful move.
    I am going to have to hammer them over this to get it fixed, more HSM staff to hate me or fusion staff, it fun when they mention your name that they are doing something you demanded, in a not so nice way, then on the next update they remove it.
    [SIGPIC][/SIGPIC]
    Aug 2007
    359
    Quote Originally Posted by LeeWay View Post
    Thanks Lee!
    Aug 2007
    359
    When I leave the first G28 line in, it gives me a Z axis soft limit exceeded warning when I try to start the code. The one at the end of the code gave me an X axis soft limit exceeded.
    Dec 2009
    594
    How does that happen. On my mach3 version restart zeros everything. I need to move to X0Y0 before shutdown to retain position.
    Jun 2004
    6618
    Quote Originally Posted by kvom View Post
    What we do at the end of the day is to remove the tool and hit a button called "Go to Z". This sends all three axes to the zero point for the current tool number. Shut down. Then start the next day and X and Y are at zero. Or Work Home. G54.
    Lee
    Try enabling persistent offsets and dro's.
    Feb 2006
    7063
    I have a VERY custom POST for HSMXpress/Fusion that I can post, provided I'm not asked to give any support for it, other than how to use the most important features. It provides a lot of added functionality, like the ability to insert prompted "stops" (the machine stops, coolant and spindle are turned off, it moves to a defined position, and prompts the user to do something, then continues where it left off when CycleStart is clicked). Toolchange position, and "Park" position can be specified in fixture coordinates or machine coordinates, SRO and FRO can be modified in the g-code on either a global, or per-operation basis, to avoid having to re-generate the g-code. It also outputs code that will run directly in CutViewer Mill, which I find invaluable for validating code before running it for the first time on the machine - CutViewer will often find things the HSMXpress/Fusion simulator will miss. It also writes nice, readable, commented G-code, with user-provided comments in each operation "header" like the below.
    Regards,
    Ray L.
    (Lock Stop Cam)
    (Job Notes
    ( Warning - ParkPos is in Machine Coordinates )
    ( Stock Size: X7.2500 Y7.2500 Z0.3750)
    ( Setup G54 To Left Front Corner of Fixture )
    ( Mount Blank Aligned to Scribe Lines on Fixture )
    ( CutViewer Setup Definitions: )
    ( STOCK/BLOCK,7.2500,7.2500,0.3750,-5.3750,-1.0625,0.0000 )
    ( FROM/0.0000,0.0000,12.0000 )
    (@ToolTable)
    (@Tool: 1 #9 Drill {0.1960}, [84], Max Depth=-0.1089)
    (@Tool: 2 1/4 x 1 2-Flute Router Bit - HSM Finishing, [1305], Max Depth=-0.0200)
    (Operation List
    ( 00:00:20 ZRange: -0.1089, 0.8750, 0.4839 Part Machining\Screw Holes Drill #9 Drill )
    ( 00:03:08 ZRange: -0.0200, 0.8750, 0.3950 Part Machining\Profiles 1/4 x 1 2-Flute Router Bit - HSM Finishing )
    ( 00:03:28 Total Time )
    (Preamble Start)
    #100 = [ 400.0000 ] (GlobalSFPM)
    #101 = [ 100.0000 ] (GlobalSSO)
    #103 = [ 100.0000 ] (OpSSO)
    #102 = [ 100.0000 ] (GlobalFRO)
    #104 = [ 100.0000 ] (OpFRO)
    #105 = [ 0.0000 ] (TCPosX)
    #106 = [ 0.0000 ] (TCPosY)
    #107 = [ 0.0000 ] (ParkPosX)
    #108 = [ 0.0000 ] (ParkPosY)
    G90 G94 G17 G54
    G20
    (TOOL/DRILL,0.125,118.0000,1.000)
    (Preamble End)
    (Operation 1 Start)
    (USR, Screw Holes Drill, Instance 1)
    G54
    (Toolchange Start)
    G53 G00 Z0.0000
    G00 X[ #105 ] Y[ #106 ]
    G49
    M05
    M09
    (Tool #84, #9 Drill)
    (TOOL/DRILL,0.1960,118.0000,2.3520)
    G43 H1
    (USR, Load Tool #1, #9 Drill)
    M00
    M03 S[3910*[#100/400.0]*[#101/100.0]*[#103/100.0]] (S3910)
    G04 P1.
    (Toolchange End)
    M07
    G00 X12.1640 Y4.6875
    G43 Z0.8750 H1
    (CUTTING)
    Z0.4750
    (Drill: #9 Drill)
    G98 G81 X12.1640 Y4.6875 Z-0.1089 R0.4050 F[19.02*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F19.02)
    X11.7401 Y3.1055
    X10.5820 Y1.9474
    X9.0000 Y1.5235
    X7.4180 Y1.9474
    X6.2599 Y3.1055
    X5.8360 Y4.6875
    X6.2599 Y6.2695
    X7.4180 Y7.4276
    X9.0000 Y7.8515
    X10.5820 Y7.4276
    X11.7401 Y6.2695
    G80
    (RAPID)
    G00 Z0.8750
    (Operation 2 Start)
    (USR, Profiles, Instance 1)
    (MStop Install Screws)
    (MStop Start)
    M05
    M09
    G53 G00 Z0.0000
    G53 G00 X[ #107 ] Y[ #108 ]
    (USR,Install Screws)
    M00
    (MStop End)
    (FRO 200)
    (Toolchange Start)
    G53 G00 Z0.0000
    G49
    M05
    M09
    (Tool #1305, 1/4 x 1 2-Flute Router Bit - HSM Finishing)
    (TOOL/MILL,0.2500,0.0000,1.0000)
    G43 H2
    (USR, Load Tool #2, 1/4 x 1 2-Flute Router Bit - HSM Finishing)
    M00
    M03 S[6000*[#100/400.0]*[#101/100.0]*[#103/100.0]] (S6000)
    G04 P1.
    (Toolchange End)
    M07
    G00 X11.7626 Y4.6625
    G43 Z0.8750 H2
    Z0.6144
    (PLUNGE)
    G01 Z0.2225 F[22.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F44.00)
    G18 G02 X11.7876 Y4.6625 Z0.1975 I0.0250 K0.0000 F[22.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F44.00)
    (LEAD IN)
    G01 X11.8126 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G17
    G03 X11.8376 Y4.6875 Z0.1975 I0.0000 J0.0250 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    (FINISH CUT)
    G03 X7.2974 Y6.9576 Z0.1975 I-2.8376 J0.0000 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X10.7026 Y2.4174 Z0.1975 I1.7026 J-2.2701 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X11.8358 Y4.7875 Z0.1975 I-1.7026 J2.2701 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    (LEAD OUT)
    X11.8100 Y4.8116 Z0.1975 I-0.0250 J-0.0009 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    G01 X11.7850 Y4.8107 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    G01 X11.7811 Y4.8106 Z0.1978 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X11.7773 Y4.8104 Z0.1987 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X11.7736 Y4.8103 Z0.2002 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X11.7703 Y4.8102 Z0.2023 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X11.7673 Y4.8101 Z0.2048 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X11.7648 Y4.8100 Z0.2078 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X11.7627 Y4.8099 Z0.2112 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X11.7612 Z0.2148 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X11.7603 Z0.2186 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X11.7600 Y4.8098 Z0.2225 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X11.7626 Y4.6625 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    (PLUNGE)
    Z0.0450 F[22.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F44.00)
    G18 G02 X11.7876 Y4.6625 Z0.0200 I0.0250 K0.0000 F[22.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F44.00)
    (LEAD IN)
    G17
    G03 X11.8376 Y4.6875 Z0.0200 I0.0000 J0.0250 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    (FINISH CUT)
    G03 X7.2974 Y6.9576 Z0.0200 I-2.8376 J0.0000 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X10.7026 Y2.4174 Z0.0200 I1.7026 J-2.2701 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X11.8358 Y4.7875 Z0.0200 I-1.7026 J2.2701 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    (LEAD OUT)
    X11.8100 Y4.8116 Z0.0200 I-0.0250 J-0.0009 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    G01 X11.7811 Y4.8106 Z0.0203 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X11.7773 Y4.8104 Z0.0212 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X11.7736 Y4.8103 Z0.0227 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X11.7703 Y4.8102 Z0.0248 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X11.7673 Y4.8101 Z0.0273 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X11.7648 Y4.8100 Z0.0303 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X11.7627 Y4.8099 Z0.0337 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X11.7612 Z0.0373 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X11.7603 Z0.0411 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X11.7600 Y4.8098 Z0.0450 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    (PLUNGE)
    Z0.0050 F[22.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F44.00)
    G18 G02 X11.7876 Y4.6625 Z-0.0200 I0.0250 K0.0000 F[22.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F44.00)
    (LEAD IN)
    G17
    G03 X11.8376 Y4.6875 Z-0.0200 I0.0000 J0.0250 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    (FINISH CUT)
    G03 X7.2974 Y6.9576 Z-0.0200 I-2.8376 J0.0000 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X10.7026 Y2.4174 Z-0.0200 I1.7026 J-2.2701 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X11.8358 Y4.7875 Z-0.0200 I-1.7026 J2.2701 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    (LEAD OUT)
    X11.8100 Y4.8116 Z-0.0200 I-0.0250 J-0.0009 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    G01 X11.7811 Y4.8106 Z-0.0197 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X11.7773 Y4.8104 Z-0.0188 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X11.7736 Y4.8103 Z-0.0173 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X11.7703 Y4.8102 Z-0.0152 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X11.7673 Y4.8101 Z-0.0127 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X11.7648 Y4.8100 Z-0.0097 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X11.7627 Y4.8099 Z-0.0063 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X11.7612 Z-0.0027 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X11.7603 Z0.0011 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X11.7600 Y4.8098 Z0.0050 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    (RAPID)
    G00 Z0.6144
    X12.6498 Y4.7124
    (PLUNGE)
    G18 G03 X12.6248 Y4.7124 Z0.1975 I-0.0250 K0.0000 F[22.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F44.00)
    (LEAD IN)
    G01 X12.5998 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G17
    G03 X12.5748 Y4.6874 Z0.1975 I0.0000 J-0.0250 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    (FINISH CUT)
    G02 X12.5717 Y4.5384 Z0.1975 I-3.5748 J0.0000 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X12.4074 Y4.3138 Z0.1975 I-0.2498 J0.0104 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G01 X12.1368 Y4.2154 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X12.0706 Y3.8581 Z0.1975 I-3.5464 J0.4720 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G01 X12.2574 Y3.7273 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X12.3482 Y3.4349 Z0.1975 I-0.1434 J-0.2048 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X12.0186 Y2.7725 Z0.1975 I-3.3481 J1.2527 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X11.7641 Y2.6602 Z0.1975 I-0.2111 J0.1339 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G01 X11.4805 Y2.7102 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X11.2445 Y2.4339 Z0.1975 I-2.8352 J2.1821 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G01 X11.3409 Y2.2272 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X11.2733 Y1.9286 Z0.1975 I-0.2266 J-0.1056 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X10.6567 Y1.5198 Z0.1975 I-2.2733 J2.7589 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X10.3801 Y1.5498 Z0.1975 I-0.1159 J0.2215 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G01 X10.1595 Y1.7349 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X9.8170 Y1.6136 Z0.1975 I-1.3642 J3.3073 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G01 X9.7971 Y1.3864 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X9.5893 Y1.1616 Z0.1975 I-0.2491 J0.0218 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X8.8508 Y1.1158 Z0.1975 I-0.5893 J3.5259 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X8.6264 Y1.2801 Z0.1975 I0.0104 J0.2498 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G01 X8.5279 Y1.5507 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X8.1706 Y1.6169 Z0.1975 I0.4722 J3.5464 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G01 X8.0398 Y1.4301 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X7.7474 Y1.3393 Z0.1975 I-0.2048 J0.1434 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X7.0850 Y1.6689 Z0.1975 I1.2527 J3.3481 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X6.9727 Y1.9234 Z0.1975 I0.1339 J0.2111 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G01 X7.0227 Y2.2070 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X6.7464 Y2.4430 Z0.1975 I2.1820 J2.8352 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G01 X6.5397 Y2.3466 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X6.2411 Y2.4142 Z0.1975 I-0.1056 J0.2266 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X5.8323 Y3.0308 Z0.1975 I2.7589 J2.2733 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X5.8623 Y3.3074 Z0.1975 I0.2215 J0.1159 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G01 X6.0474 Y3.5280 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X5.9261 Y3.8705 Z0.1975 I3.3073 J1.3642 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G01 X5.6989 Y3.8904 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X5.4741 Y4.0982 Z0.1975 I0.0218 J0.2490 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X5.4283 Y4.8366 Z0.1975 I3.5259 J0.5894 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X5.5926 Y5.0612 Z0.1975 I0.2498 J-0.0104 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G01 X5.8632 Y5.1596 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X5.9294 Y5.5169 Z0.1975 I3.5464 J-0.4720 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G01 X5.7426 Y5.6477 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X5.6518 Y5.9401 Z0.1975 I0.1434 J0.2048 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X5.9814 Y6.6025 Z0.1975 I3.3481 J-1.2527 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X6.2359 Y6.7148 Z0.1975 I0.2111 J-0.1339 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G01 X6.5195 Y6.6648 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X6.7555 Y6.9411 Z0.1975 I2.8351 J-2.1822 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G01 X6.6591 Y7.1478 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X6.7267 Y7.4464 Z0.1975 I0.2266 J0.1057 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X7.3433 Y7.8553 Z0.1975 I2.2732 J-2.7589 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X7.6199 Y7.8253 Z0.1975 I0.1159 J-0.2216 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G01 X7.8405 Y7.6401 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X8.1830 Y7.7614 Z0.1975 I1.3642 J-3.3074 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G01 X8.2029 Y7.9886 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X8.4107 Y8.2134 Z0.1975 I0.2491 J-0.0218 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X9.1492 Y8.2592 Z0.1975 I0.5892 J-3.5259 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X9.3736 Y8.0949 Z0.1975 I-0.0104 J-0.2498 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G01 X9.4721 Y7.8243 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X9.8294 Y7.7581 Z0.1975 I-0.4724 J-3.5463 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G01 X9.9602 Y7.9449 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X10.2526 Y8.0357 Z0.1975 I0.2048 J-0.1434 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X10.9150 Y7.7061 Z0.1975 I-1.2526 J-3.3481 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X11.0273 Y7.4516 Z0.1975 I-0.1339 J-0.2111 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G01 X10.9773 Y7.1680 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X11.2536 Y6.9320 Z0.1975 I-2.1822 J-2.8351 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G01 X11.4603 Y7.0284 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X11.7589 Y6.9608 Z0.1975 I0.1057 J-0.2266 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X12.1677 Y6.3442 Z0.1975 I-2.7589 J-2.2733 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X12.1377 Y6.0676 Z0.1975 I-0.2215 J-0.1159 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G01 X11.9526 Y5.8470 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X12.0739 Y5.5045 Z0.1975 I-3.3073 J-1.3643 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G01 X12.3011 Y5.4846 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X12.5259 Y5.2768 Z0.1975 I-0.0218 J-0.2490 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X12.5734 Y4.5874 Z0.1975 I-3.5259 J-0.5894 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    (LEAD OUT)
    G03 X12.5977 Y4.5617 Z0.1975 I0.0250 J-0.0007 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    G01 X12.6227 Y4.5610 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    G01 X12.6266 Y4.5609 Z0.1978 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X12.6304 Y4.5608 Z0.1987 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X12.6340 Y4.5607 Z0.2002 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X12.6374 Y4.5606 Z0.2023 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X12.6404 Z0.2048 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X12.6429 Y4.5605 Z0.2078 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X12.6450 Y4.5604 Z0.2112 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X12.6465 Z0.2148 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X12.6474 Z0.2186 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X12.6477 Y4.5603 Z0.2225 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X12.6498 Y4.7124 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    (PLUNGE)
    G18 G03 X12.6248 Y4.7124 Z0.0200 I-0.0250 K0.0000 F[22.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F44.00)
    (LEAD IN)
    G17
    G03 X12.5748 Y4.6874 Z0.0200 I0.0000 J-0.0250 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    (FINISH CUT)
    G02 X12.5717 Y4.5384 Z0.0200 I-3.5748 J0.0000 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X12.4074 Y4.3138 Z0.0200 I-0.2498 J0.0104 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X12.0706 Y3.8581 Z0.0200 I-3.5464 J0.4720 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X12.3482 Y3.4349 Z0.0200 I-0.1434 J-0.2048 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X12.0186 Y2.7725 Z0.0200 I-3.3481 J1.2527 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X11.7641 Y2.6602 Z0.0200 I-0.2111 J0.1339 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X11.2445 Y2.4339 Z0.0200 I-2.8352 J2.1821 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X11.2733 Y1.9286 Z0.0200 I-0.2266 J-0.1056 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X10.6567 Y1.5198 Z0.0200 I-2.2733 J2.7589 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X10.3801 Y1.5498 Z0.0200 I-0.1159 J0.2215 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X9.8170 Y1.6136 Z0.0200 I-1.3642 J3.3073 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X9.5893 Y1.1616 Z0.0200 I-0.2491 J0.0218 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X8.8508 Y1.1158 Z0.0200 I-0.5893 J3.5259 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X8.6264 Y1.2801 Z0.0200 I0.0104 J0.2498 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X8.1706 Y1.6169 Z0.0200 I0.4722 J3.5464 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X7.7474 Y1.3393 Z0.0200 I-0.2048 J0.1434 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X7.0850 Y1.6689 Z0.0200 I1.2527 J3.3481 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X6.9727 Y1.9234 Z0.0200 I0.1339 J0.2111 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X6.7464 Y2.4430 Z0.0200 I2.1820 J2.8352 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X6.2411 Y2.4142 Z0.0200 I-0.1056 J0.2266 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X5.8323 Y3.0308 Z0.0200 I2.7589 J2.2733 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X5.8623 Y3.3074 Z0.0200 I0.2215 J0.1159 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X5.9261 Y3.8705 Z0.0200 I3.3073 J1.3642 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X5.4741 Y4.0982 Z0.0200 I0.0218 J0.2490 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X5.4283 Y4.8366 Z0.0200 I3.5259 J0.5894 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X5.5926 Y5.0612 Z0.0200 I0.2498 J-0.0104 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X5.9294 Y5.5169 Z0.0200 I3.5464 J-0.4720 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X5.6518 Y5.9401 Z0.0200 I0.1434 J0.2048 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X5.9814 Y6.6025 Z0.0200 I3.3481 J-1.2527 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X6.2359 Y6.7148 Z0.0200 I0.2111 J-0.1339 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X6.7555 Y6.9411 Z0.0200 I2.8351 J-2.1822 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X6.7267 Y7.4464 Z0.0200 I0.2266 J0.1057 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X7.3433 Y7.8553 Z0.0200 I2.2732 J-2.7589 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X7.6199 Y7.8253 Z0.0200 I0.1159 J-0.2216 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X8.1830 Y7.7614 Z0.0200 I1.3642 J-3.3074 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X8.4107 Y8.2134 Z0.0200 I0.2491 J-0.0218 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X9.1492 Y8.2592 Z0.0200 I0.5892 J-3.5259 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X9.3736 Y8.0949 Z0.0200 I-0.0104 J-0.2498 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X9.8294 Y7.7581 Z0.0200 I-0.4724 J-3.5463 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X10.2526 Y8.0357 Z0.0200 I0.2048 J-0.1434 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X10.9150 Y7.7061 Z0.0200 I-1.2526 J-3.3481 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X11.0273 Y7.4516 Z0.0200 I-0.1339 J-0.2111 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X11.2536 Y6.9320 Z0.0200 I-2.1822 J-2.8351 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X11.7589 Y6.9608 Z0.0200 I0.1057 J-0.2266 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X12.1677 Y6.3442 Z0.0200 I-2.7589 J-2.2733 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X12.1377 Y6.0676 Z0.0200 I-0.2215 J-0.1159 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X12.0739 Y5.5045 Z0.0200 I-3.3073 J-1.3643 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X12.5259 Y5.2768 Z0.0200 I-0.0218 J-0.2490 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X12.5734 Y4.5874 Z0.0200 I-3.5259 J-0.5894 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    (LEAD OUT)
    G03 X12.5977 Y4.5617 Z0.0200 I0.0250 J-0.0007 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    G01 X12.6266 Y4.5609 Z0.0203 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X12.6304 Y4.5608 Z0.0212 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X12.6340 Y4.5607 Z0.0227 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X12.6374 Y4.5606 Z0.0248 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X12.6404 Z0.0273 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X12.6429 Y4.5605 Z0.0303 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X12.6450 Y4.5604 Z0.0337 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X12.6465 Z0.0373 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X12.6474 Z0.0411 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X12.6477 Y4.5603 Z0.0450 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    (PLUNGE)
    G18 G03 X12.6248 Y4.7124 Z-0.0200 I-0.0250 K0.0000 F[22.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F44.00)
    (LEAD IN)
    G17
    G03 X12.5748 Y4.6874 Z-0.0200 I0.0000 J-0.0250 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    (FINISH CUT)
    G02 X12.5717 Y4.5384 Z-0.0200 I-3.5748 J0.0000 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X12.4074 Y4.3138 Z-0.0200 I-0.2498 J0.0104 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X12.0706 Y3.8581 Z-0.0200 I-3.5464 J0.4720 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X12.3482 Y3.4349 Z-0.0200 I-0.1434 J-0.2048 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X12.0186 Y2.7725 Z-0.0200 I-3.3481 J1.2527 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X11.7641 Y2.6602 Z-0.0200 I-0.2111 J0.1339 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X11.2445 Y2.4339 Z-0.0200 I-2.8352 J2.1821 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X11.2733 Y1.9286 Z-0.0200 I-0.2266 J-0.1056 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X10.6567 Y1.5198 Z-0.0200 I-2.2733 J2.7589 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X10.3801 Y1.5498 Z-0.0200 I-0.1159 J0.2215 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X9.8170 Y1.6136 Z-0.0200 I-1.3642 J3.3073 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X9.5893 Y1.1616 Z-0.0200 I-0.2491 J0.0218 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X8.8508 Y1.1158 Z-0.0200 I-0.5893 J3.5259 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X8.6264 Y1.2801 Z-0.0200 I0.0104 J0.2498 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X8.1706 Y1.6169 Z-0.0200 I0.4722 J3.5464 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X7.7474 Y1.3393 Z-0.0200 I-0.2048 J0.1434 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X7.0850 Y1.6689 Z-0.0200 I1.2527 J3.3481 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X6.9727 Y1.9234 Z-0.0200 I0.1339 J0.2111 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X6.7464 Y2.4430 Z-0.0200 I2.1820 J2.8352 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X6.2411 Y2.4142 Z-0.0200 I-0.1056 J0.2266 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X5.8323 Y3.0308 Z-0.0200 I2.7589 J2.2733 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X5.8623 Y3.3074 Z-0.0200 I0.2215 J0.1159 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X5.9261 Y3.8705 Z-0.0200 I3.3073 J1.3642 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X5.4741 Y4.0982 Z-0.0200 I0.0218 J0.2490 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X5.4283 Y4.8366 Z-0.0200 I3.5259 J0.5894 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X5.5926 Y5.0612 Z-0.0200 I0.2498 J-0.0104 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X5.9294 Y5.5169 Z-0.0200 I3.5464 J-0.4720 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X5.6518 Y5.9401 Z-0.0200 I0.1434 J0.2048 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X5.9814 Y6.6025 Z-0.0200 I3.3481 J-1.2527 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X6.2359 Y6.7148 Z-0.0200 I0.2111 J-0.1339 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X6.7555 Y6.9411 Z-0.0200 I2.8351 J-2.1822 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X6.7267 Y7.4464 Z-0.0200 I0.2266 J0.1057 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X7.3433 Y7.8553 Z-0.0200 I2.2732 J-2.7589 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X7.6199 Y7.8253 Z-0.0200 I0.1159 J-0.2216 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X8.1830 Y7.7614 Z-0.0200 I1.3642 J-3.3074 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X8.4107 Y8.2134 Z-0.0200 I0.2491 J-0.0218 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X9.1492 Y8.2592 Z-0.0200 I0.5892 J-3.5259 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X9.3736 Y8.0949 Z-0.0200 I-0.0104 J-0.2498 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X9.8294 Y7.7581 Z-0.0200 I-0.4724 J-3.5463 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X10.2526 Y8.0357 Z-0.0200 I0.2048 J-0.1434 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X10.9150 Y7.7061 Z-0.0200 I-1.2526 J-3.3481 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X11.0273 Y7.4516 Z-0.0200 I-0.1339 J-0.2111 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X11.2536 Y6.9320 Z-0.0200 I-2.1822 J-2.8351 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X11.7589 Y6.9608 Z-0.0200 I0.1057 J-0.2266 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X12.1677 Y6.3442 Z-0.0200 I-2.7589 J-2.2733 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X12.1377 Y6.0676 Z-0.0200 I-0.2215 J-0.1159 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X12.0739 Y5.5045 Z-0.0200 I-3.3073 J-1.3643 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    G02 X12.5259 Y5.2768 Z-0.0200 I-0.0218 J-0.2490 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    X12.5734 Y4.5874 Z-0.0200 I-3.5259 J-0.5894 F[44.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F88.00)
    (LEAD OUT)
    G03 X12.5977 Y4.5617 Z-0.0200 I0.0250 J-0.0007 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    G01 X12.6266 Y4.5609 Z-0.0197 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X12.6304 Y4.5608 Z-0.0188 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X12.6340 Y4.5607 Z-0.0173 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X12.6374 Y4.5606 Z-0.0152 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X12.6404 Z-0.0127 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X12.6429 Y4.5605 Z-0.0097 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X12.6450 Y4.5604 Z-0.0063 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X12.6465 Z-0.0027 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X12.6474 Z0.0011 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    X12.6477 Y4.5603 Z0.0050 F[250.00*[#100/400.0]*[#102/100.0]*[#104/100.0]] (F500.00)
    (RAPID)
    G00 Z0.8750
    (Postamble Start)
    M09 M05
    G49 G54 G90
    M05
    M09
    G53 G00 Z0.0000
    (USR, Program Done)
    M30
    (Program Extents
    ( X=0.0000/12.6498)
    ( Y=0.0000/8.2592)
    ( Z=-0.1089/0.8750)
    (Program End)
Page 1 of 4 123
  1. Post processing problems
    By Brad_cnc in forum BobCad Post Processors
    Last Post: 08-01-2014, 03:14 PM
  2. Post Processing
    By machineitright in forum Dolphin CAD/CAM
    Last Post: 02-06-2012, 11:56 PM
  3. ISO post processing
    By imbalanced_MJR in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 08-23-2011, 08:05 AM
  4. Post processing.....
    By MrWild in forum Dolphin CAD/CAM
    Last Post: 03-22-2008, 07:43 AM
  5. Post Processing with MasterCAM X
    By kzoojam2006 in forum Post Processors for MC
    Last Post: 08-11-2006, 07:55 AM
