585,748 active members*
3,400 visitors online*
IndustryArena Forum > CAM Software > CamBam > Hi All Can enybody help me convert this cambam files to Gcode that can use on Mach3
Results 1 to 3 of 3
    Sep 2014
    12
    two files in rarfile , I wold be greatful Happy for eny help here on this
    Nov 2009
    77
    Re: Hi All Can enybody help me convert this cambam files to Gcode that can use on M
    You have to select the post processor. It's one of the configuration settings. There are two tabs at the top left, Drawing and System. Choose System and look down the tree for post processors. Choose Mach3.
    cnc1000
    Sep 2014
    12
    The problem its Idont have eny software ore machines here A friend of me need gcodeof the file to do the work for me. Is there no one can do this for me ??
  1. Replies: 2
    Last Post: 01-16-2016, 03:23 AM
  2. need to convert conventional gcode in vbscript for mach3
    By revolucion in forum Visual Basic
    Last Post: 05-30-2015, 12:00 AM
  3. I will pay for someone to convert STL to Gcode (mach3)
    By Davidodem in forum Want To Buy...Need help!
    Last Post: 07-20-2013, 07:32 AM
  4. MACH3 interpreting CAMBAM GCODE wrong
    By jsearles in forum CamBam
    Last Post: 09-30-2012, 02:45 AM
  5. Import/Convert DXF or PLT files to Mach3....
    By Mikael in forum Mach Mill
    Last Post: 12-25-2008, 10:33 AM
