585,883 active members*
5,827 visitors online*
IndustryArena Forum > CAM Software > SprutCAM > sprutcam 9 "smart cut" feed, anyone uses this?
Results 1 to 10 of 10
    Nov 2012
    104
    i've used this option for 4 years on sprutcam8 pcnc post and haven't had a single issue, maybe 100 programs, all run exactly as programmed, just recently upgraded to sprutcam9 all post and now i'm having issues.
    anyone else running smart cut feed or are you guys just editing values in the individual drop downs: work feed, cut feed, plunge feed, approach feed etc etc etc
    thanks guys
    Carlos
    Nov 2012
    104
    Re: sprutcam 9 "smart cut" feed, anyone uses this?
    no one???????
    Jun 2014
    1780
    Quote Originally Posted by TPR View Post
    thanks guys
    Carlos
    I use sprut 7 which has this for an option, I have never used it though, I specify a feed rate, I have gotten used to doing it that way.
    mike sr
    Nov 2007
    2151
    I used it a few times and reviewed the code generated. Did not fully understand how this is implemented in the post processor and that is the key to every setting in sprutcam. Not every setting results in code generated or correct code generated, the post is everything when it comes to results. As I mentioned in another thread about tap functions have no less then 50 different setting and no less then 30 of them generate NO code no matter how they are set. About all I can say is experiment with settings and review what code is generated until you get what you want
    Nov 2012
    104
    thanks guys, it was a bug in SC9, they have now fixed it, and release a new version with the fix.
    Nov 2007
    2151
    So what is the secret here?
    What is difference in feed settings generated in code?
    I would like to use all those settings and find they don't do much with the code generated.
    Does it do any of this based on material hardness? It has table for this but I find no way to make it all work.
    Any comments would be great.
    Nov 2012
    104
    smartcut just gives you 1 location to set feed speed, plunge speed and retract speed in one place instead of flipping thru different drop downs.
    that's really all it does as far as I know. i've always used it in SC8 pcnc post with ZERO issues and when I upgraded to SC9 all post, it was doing some silly stuff, like trying to plunge at 50 IPM instead of 5 IPM like I programmed, John and Jacob at tormach identified the issue and worked with sprutcam to fix the bug.
    we are now smart cut feeding and business as usual, thanks guys (John and Jacob)
    Nov 2012
    104
    and the problem is back...... lol
    Nov 2007
    2151
    lol
    That is a major frustration of Sprutcam. All the fancy features it has for operations are not part of the post for tormach. Just this last week I spent hours of research and setting up variable depth pecking operations on a number of parts I was having problem with. Only to figure out that those settings like so many others do nothing but look good in a simulator they translate to no code at the machine. And or broken tools and spoiled parts.
    Wish they would provide a guide showing all the settings that translate into nothing so users don't waste time. Glad I don't use Sprutcam to make a living.
    Nov 2012
    104
    AND THE ISSUE IS BACK AGAIN, SO IT SEEMS LIKE EVERY 2 YEARS THIS ****ING ISSUE RAISES ITS DAMN HEAD.
  1. "SprutCAM License Activation" emails
    By dkaustin in forum SprutCAM
    Last Post: 12-12-2014, 09:06 PM
  2. Need help working out feed rate for "C" Axis and "Z" axis simultaneously.
    By Jonaldhinio in forum Australia, New Zealand Club House
    Last Post: 08-12-2014, 09:27 AM
  3. Replies: 3
    Last Post: 06-25-2014, 03:51 PM
  4. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  5. EXLAS "smart" Desktop laser-COMING SOON
    By EXLASer in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-26-2011, 02:19 PM
