Hey everybody, thanks for reading my post. I am having a problem with my THC, I am hoping I can locate a sharp person in the community that can help me out.
Specs:
Machine: J-CUT 4'x10'
DTHC: Start Saphon SH-HC30 digital height control
Plasma Source: Hypertherm Powermax 85 amp - with factory control cable for carrying volts to controller, set at 50:1 voltage reduction, out from the plasma source.
Software: FastCAM
Problem:
As soon as I start a cut with the THC active, the torch lifts to max point. Acts is if the THC is not receiving any signal.
Solutions I have attempted with no results:
-Adjust all parameters in the THC (obviously, that was my first thing to attempt) the results are the same. Acts like no voltage is being sent to control.
-Tested voltage out with a multi-meter into the CNC control. Voltage is being sent from the Hypertherm unit when arc is present
-Reversed polarity on the arc voltage out, to see if it was a polarity issue.
-tested continuity from the plate bas (steel on table) to the torch shield - continuity it present.
I have put a email into both J-Cut (ABSOLUTELY NO HELP), and Start Microstep. They have replied, but have not found a solution at this point.
This is my second J-Cut machine - the machines are ok, but you better be a self motivated learner- or speak Mandarin.
Any help is highly appreciated!!
Larry
