I was wondering, since a laser head can be basically the size of a standard laser pointer, can a laser cutter be mounted in a r8 collet and then use my x3 for the tool paths?
Seems like it should work but im not the expert.
yep, you can do it.
Some old machines move the material rather than the beam.
In fact some new machine still use this idea where there is a punching head next to it (combination machine).
The problem you would be facing is the beam will hit the bottom of your table once the material is cut through.
What do commercial laser engravers use to prevent the area under the work surface from being struck or damaged by the laser?
I would say it is metal.
Engraving are on the surface only, while cutting the beam penetrates the workpiece and the bottom is mostly of mild steel.
So If I just wanted to do laser engraving in wood, plastic and sheet metal with out cutting all the way through, what watt size should I be searching for?
Is there any suppliers to look at specifically?
If you need to engrave on sheet metal a YAG laser should be chosen.
Normally the wattage is quite low for YAG lasers to engrave metal.
For CO2 lasers the wattage required is much higher.
Sorry i would not recommend, as there is a large number of suppliers.
