Thanks for the link, Bob. I missed your reply until now :rainfro:
It is smaller at the tailstock end of the cut.
Gramps, I think that means your work is closer to the tool at the tail than the head. You should be able to see that much difference if you put dead centers in both ends and bring them together. If you can't see it, you can put a straight edge flat between the centers, then gently bring the center in the tail in to tighten it slightly, and the side that's off will move away from the tail. For testing horizontal alignment, you will want the long edge horizontal, the width of the ruler vertical and the thickness of the rule pinched between the centers. Flip the length so it's vertical to test vertical alignment.
Wen I was young, I spent most of my money on fast women, slow horses, and cheap booze. The rest of it I just wasted.
