There you go, the pan heater would do all that has already been meantioned & also not use very much electric so the bill want get run up.
My thoughts on the oil is that the tranny fluid would be just the ticket. you can also get it in Sin version & it comes in two weights. You could run the thinner in the cold weather & the thicker in the summer. It is still a little multy Visc though I believe. Like 80w90 but this is very little change. You also dont want any of the gear oils that is labeled any type of Syncromesh, which is a type that has additives to help the syncronizers in manual trannies grab each other ( anty slip additive, makes parts grab each other).
Heck this oil here should work here is a link for something that would be great & help the little lathe last better also. It would work year around (hot or cold). I bet you wouldnt have to heat the lathe either this is good stuff I have used it in many type gear boxes.
http://www.amsoil.com/StoreFront/agl.aspx
Cheap it is not. But I bet if you look around you will find someone that carries it local. I copied part of the info & will paste it here. Others could give a idea if they think it will fit the bill also. We dont want to put the wrong thing in there. Its not rocket science anyway, I believe this will be just the thing.
Synthetic Gear Lube SAE 80W-90 (AGL)
High quality replacement for applications specifying SAE 80W-90 conventional gear lube. Synthetic construction provides improved cold flow properties, high viscosity index and heat resistance. Contains an over treat of high quality additives, exceeding the minimum standards. Provides excellent wear protection and long equipment life.
See Pricing Information or Place an Order
Package sizes include:
1-Quart Bottle
1-Quart Bottles (case of 12)
1-Gallon Bottle
1-Gallon Bottles (case of 4)
5-Gallon Pail
16-Gallon Keg
30-Gallon Drums
55-Gallon Drums
PRODUCT DESCRIPTION
AMSOIL 80W-90 Synthetic Gear Lube is a multi-functional product designed to surpass the requirements of equipment and automotive applications calling for an SAE 80W-90 viscosity grade. Formulated with wax-free synthetic base oils and high quality additives, AMSOIL 80W-90 Synthetic Gear Lube resists thermal breakdown. Its naturally high viscosity index and shear stable construction improves film strength and viscosity retention. AMSOIL Synthetic 80W-90 Gear Lube prevents wear, resists heat, and protects gears. It lasts longer in service than conventional gear oils and increases equipment life.
AMSOIL Synthetic 80W-90 Gear Lube provides:
- High Load Gear and Bearing Protection
- Longer Oil and Equipment Life
- Lower Maintenance Costs
- Compatibility With Conventional and Synthetic Gear Lubes
- Multi-functional for Multiple Applications
APPLICATIONS
AMSOIL Synthetic 80W-90 Synthetic Gear Lube is recommended for use under various combinations of high-speed, shock loads, low speeds and high torque conditions. It is recommended for use in all light and heavy-duty, automotive, commercial or industrial applications requiring SAE 80W-90 EP gear lube. AMSOIL Synthetic 80W-90 Gear Lube replaces all conventional 80W-90 gear oils and exceeds the lubrication and performance requirements of front and rear differentials, transfer cases, transaxles, manual transmissions, oil lubricated wheel bearings, and steering gear boxes that require any of the following specifications:
- <LI class=style2>API GL-5 & MT-1 <LI class=style2>MIL-PRF-2105E <LI class=style2>Dana SHAES 234 (Formerly Eaton PS-037) for 250,000 miles <LI class=style2>MACK GO-J <LI class=style2>Arvin/Meritor 0-76D plus hypoid gear oil specifications from all domestic and foreign manufacturers such as GM, Ford and Daimler Chrysler.
- Can also be used rear axles where API Service GL-4 lubricant is recommended.
There is a lot more info than this but you get the idea.
I will have to agree about there is probably a spec for the oil in all the mini lathes, they probably all use the same thing to but some manufacters might install better grade of the type needed.
Its good to here you like the lathe. If I buy a lathe this small it will be this lathe. I have my eye on one that is bigger though but you know how that goes. Budget may get in the way. If it does a BB 10x18 (under a diff name) will be what hits the floor. They make this same lathe in a 10x27 with VFD that goes from about 50-2200 spindle speed that I am hoping to get. It is sold under a different name but the same lathe. They also have the 10x18 if I end up getting it & the compainy being in the USA should help me out being thats where I am. You will have to post some pics of the peices you cut if you can.
Jess
