Originally Posted by
mlaws1172
Gecko 320/340 drives will handle 20 amps/80volts (brush type motors). If you are converting an existing machine you might need a controller (Mach software), breakout board, and new encoders.
If you want to make it easy on yourself get ahold of CandCNC (CandCNC.com) or another supplier who can sell you everything you need in one package.
I will look and see if I can find the spec.s for your motors. You can also check your power supply and see what it is rated for. This will give you a preety good idea if they will work.
mike
