585,754 active members*
4,168 visitors online*
IndustryArena Forum > CNC Electronics > Leadshine > Is it possible to disable 'Position following error protection' on a ES-D1008 drive?
    Jan 2016
    I am building a servo driven force feedback steering wheel, and need my servo to rotate freely until a control signal is sent to the servo drive.
    A description of a similar project can be found here: OpenSimwheel – Ascher Racing
    Using a Leadshine ES-D1008 servo drive I have almost accomplished this, but the 'Position following error protection' is triggered after a short time.
    I guess this is because the rotation of the servo registered by the encoder doesn't match the control signal.
    I have tried increasing the value 'Position error limit' in the 'Parameters' section of the Protuner software, but this didn't solve the problem.
    Is it possible to disable 'Position following error protection' on the ES-D1008 servo drive?
    If it cannot be disabled, are there then other solutions, perhaps hardware that can be added to solve the problem?
    Software and manuals can be downloaded here:
    ES-D Series Easy Servo Drives / Closed Loop Stepper Drives | Leadshine
    Any help or suggestions will be much appreciated
    May 2015
    13
    Re: Is it possible to disable 'Position following error protection' on a ES-D1008 dri
    Quote Originally Posted by sikjar View Post
    Hi, have you solved this issue? I have an ACS806 and 57BL180D servo from Leadshine that suffer from the same problem...
    Thanks, Matteo.
    Dec 2011
    155
    Quote Originally Posted by Moriduri View Post
    Thanks, Matteo.
    Not sure if you are still working on this but for others who search and bring this up, I have set the position lead error very high on my drives with my cnc so that they must miss 20 rotations to fault. it works.
  1. EZ-TRAK - “Possible Pointer Error - General Protection Fault”
    By Litespeed in forum Bridgeport / Hardinge Mills
    Last Post: 12-29-2015, 10:41 PM
  2. Replies: 1
    Last Post: 07-27-2013, 03:53 PM
  3. G320 Position Error Fault Disable
    By keebler303 in forum Gecko Drives
    Last Post: 01-10-2012, 03:37 AM
  4. Possible to disable error correction?
    By tome9999 in forum CNC Machine Related Electronics
    Last Post: 12-13-2011, 11:09 AM
