585,599 active members*
3,539 visitors online*
Results 1 to 7 of 7
    Jan 2016
    4
    water algae problem
    hi my friends;
    sory for my bad english
    i did build laser cutter...
    i used 40w chinese laser tube..
    cooling with radiator and aquarium pump
    but have a problem
    do water is algae!
    what kind of water do i put?
    pure red antifreeze is available?
    Regards..
    Murat...
    Jan 2008
    940
    Re: water algae problem
    I use the Pink RV antifreeze but have also used distilled water with a little aquarium algaecide in it
    Sep 2014
    123
    The RV stuff is really good from my experience with water cooled machinery in general, i did a similar mixture of coolant for my laser when i got that. Another thing you can do is distilled water and a general purpose biocide, if you know any place or anyone into PC water cooling they will know biocide. It literally takes a few drops to treat a gallon or so of water. I put a 60/40 mix of distilled water to RV antifreeze plus a small amount of biocide in the water reservoir for my laser after doing the same for a friends water cooled CNC engraver, he has the chinese one with the 1000w water cooled spindle motor. After two years he hasn't had any growth so i did the same for my laser. Although i will probably do an annual flush and refill just to keep things clean.
    The first thing you have to do though now is get it clean! There has been quite a few posts on here about that, a bleach and water mix circulated for a while to kill everything and clean it then flush it out well to remove the bleach because you don't want that in there any longer then necessary, then refill with fresh coolant.
    Jan 2016
    4
    Thanks for reply..
    I will try them first thing tomorrow.
    then I'll share again
    Murat
    Jan 2016
    4
    Attachment 305568
    THANKS for all reply
    May 2014
    4
    Quote Originally Posted by enrique1524 View Post
    Attachment 305568
    That's one hot looking laser
    Sent from my SAMSUNG-SM-G920A using Tapatalk
    Jan 2016
    4
    yes
    pink and hearts
  1. new weike LC1612 water flow problem
    By gravoservis in forum G.Weike Laser
    Last Post: 01-16-2015, 11:13 PM
  2. Purified water vs. distilled water vs. deionized water
    By SDSUSA in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-23-2013, 10:19 AM
  3. water jet problem
    By jeem in forum Waterjet General Topics
    Last Post: 07-03-2012, 07:52 PM
  4. Algae in the de-ionised water?
    By Magritte in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-01-2010, 10:11 PM
