585,605 active members*
3,247 visitors online*
Results 1 to 6 of 6
    Jan 2016
    Small Turning work required
    I am looking to have a small item turned and was wondering if someone could provide me with a quote.
    I require an 8mm rod 32mm in length with a m8 (1.25 pitch) thread cut 17mm into one end and 4mm into the other leaving 11mm uncut (I can provide a cad dxf if required).
    The unthreaded section will eventually hold a needle roller bearing so will need to be relatively hard. I have some 8mm 304 precision ground stainless steel rod that may be suitable subject to your advice.
    Adsey
    Jul 2015
    18
    Re: Small Turning work required
    Quantity?
    Sent from my LG-V410 using Tapatalk
    Jan 2016
    Quantity: 1
    Feb 2014
    92
    Is this possible to provide your email contact to us at this email address [email protected]
    We will like to discuss further with you on this parts. Thanks.
    BR
    /SL Wong
    Sales Manager
    Proto Tree LLC
    Website: Proto Tree
    Email: [email protected]
    I am very late for this RFQ. But for similar needs, please send drawing at [email protected].
    We manufacture components for companies in UK, FRANCE and GERMANY,
  1. Required to delete axis from Turning centre
    By Vishal N in forum Servo Motors / Drives
    Last Post: 04-13-2024, 12:10 AM
  2. Replies: 7
    Last Post: 03-03-2015, 08:12 PM
  3. Small Run Prototype - Milling Required
    By AllSpeedLLC in forum North America RFQ's
    Last Post: 09-16-2014, 04:47 PM
  4. Required ROM IC's Data for FEMCO CNC Turning Center With Fanuc 10T Series
    By james anderson in forum Wood Lathes / Mills
    Last Post: 12-12-2012, 09:49 AM
  5. Questions -- Small CNC Router with VERY SMALL Work Area, Ideas?
    By Building in forum DIY CNC Router Table Machines
    Last Post: 02-03-2012, 11:36 PM
