Re: Work zero questions
Originally Posted by
corndog
Just starting out here and using a VF2. I'm exploring the VQC page and am able to set tool offsets with the probe on the table and am now moving on to probing the work piece. I'm able to probe X/Y/Z seemingly fine, but I was curious about the offsets the machine recorded. If I manually move X and Y to match what was recorded with the probe, they appear to match up to the corner of the part correctly, but the Z doesn't match up by at least a couple/few inches. I don't remember the exact numbers, but the Z is something like +4.xx when all the way up and about -8.xx when the probe is roughly at the top of the part, but the machine recorded something like -14.xx, is this okay? Is it basically recording where the part is from the bottom of the spindle and not the tip of the probe?
Also, a previous part had been probed and the offset was recorded to G54, but I mistakenly probed to this one to G56. I don't imagine it's a good thing to have multiple work offsets saved this way? I should either delete G54, or copy the info from G56 to G54 and then delete G56?
Finally, is setting the work offset the same as setting the origin? As in, when I draw something up in Mastercam, I should make sure the origin is in the same corner that I probe on the machine?
Yes, the work offset value is the height from machine Z zero.
It doesn't matter how many offsets you have set in the offset page, as long as you are referencing the right one in your program!
Yes, origin in Mastercam and work offset zero are the same thing. You need to set zero on the part the same as you drew it in Mastercam, if you want the part to machine right.
Happy milling!
____________________________
My blog: http://www.fletch1.com
