Re: Strength Carbon vs Stainless + Machining on Tormach
1. Is there any side loading on the "blade"?
2. How is the "blade" stressed? Any part in compression (carbon fiber doesn't do so well in that application).
3. Does the "tooth" have to interact with anything? i.e., will it be subject to any rubbing?
4. Is any of this a moving part that would be subject to vibration that can lead to fatigue?
The problem is that you really answer this you need an ME to run some structural analysis of it (assuming this is a critical part). Why are you thinking carbon fiber instead of stainless?
Tim
Tormach 1100-3, Grizzly G0709 lathe, Clausing 8520 mill, SolidWorks, HSMWorks.
