585,973 active members*
4,213 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Omni CNC > Omni 1325 Machine Banging against positive Y
    Thumbs up Omni 1325 Machine Banging against positive Y
    We can't figure out why the machine bangs against the stop when we press positive or negative Y on the controller. If we send it home it bangs against the stop in the Y direction.
    Aug 2009
    655
    Re: Omni 1325 Machine Banging against positive Y
    The most obvious thing to look at is that the Y limit switch is in the correct position. If I recall looking at another omni machine (as mine is on the boat), they use proximity limit switches. On my chinese laser cutting I have one that could twist a little and when it did, that axis would hit the hard stop. With a CNC (especially if with a linear tool changer, you want to make sure your limits are solid and don't move.
    So I would check that first.
    In case anyone is wondering, I'm the twin of the other gfacer on cnczone...
    Mar 2015
    31
    Quote Originally Posted by digcraftlab View Post
    Are you performing a home function immediately after you power up the machine? On mine all the stops crash until I do.
    Dec 2015
    I had it happen to me as well.... the problem was the screw/bolts under the table .... from where I was attaching the table legs. I had 2 washers and they were making the bolts sticking out, not letting the machine gantry reach it home sensor.
    Hope that helps.
    Cheers
  1. OMNI-CNC 1325 on its way!
    By Jzarski in forum Chinese Machines
    Last Post: 10-28-2016, 08:09 AM
  2. 1325 machine ordered from Omni cnc
    By jbobrout34 in forum Chinese Machines
    Last Post: 08-22-2015, 02:38 AM
  3. OMNI 1325 or CRP 48x96 - which should I buy?
    By Cos-mo-bro in forum Chinese Machines
    Last Post: 02-08-2015, 05:31 PM
  4. Replies: 12
    Last Post: 02-02-2015, 11:52 AM
  5. New Machine Build from Omni CNC 1325
    By tcmartin61 in forum Omni CNC
    Last Post: 11-29-2014, 03:57 PM
