585,591 active members*
2,489 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Milltronics VM-17 vfd spindle enable, spindle test.
Results 1 to 6 of 6
    May 2010
    54
    Got the mill powered and able to home all axis. I bought the mill with the vfd on the spindle removed and laying in the control cabinet. I am missing a manual for this machine and want to try to run the spindle to see if the vfd is in fact bad. Can any one tell me how to enable the spindle and possible a g code to run the spindle. The spindle vfd is a Magnatek GPD-515. The parameters have been checked and all proper lights are on. Should I try to operate in local first? Thanks, Chris.
    May 2010
    54
    Re: Milltronics VM-17 vfd spindle enable, spindle test.
    Talked to Sporty Bob. He had the spindle going in 5 minutes. Thanks Bob.
    Apr 2008
    99
    WOW!!! that is pretty good service. Were you able to accomplish it over the phone?
    Dave
    May 2010
    54
    Yes sir, all over the phone!
    May 2015
    14
    I've dealt with Bob over the phone as well, He's sharp, and has my complete recommendation.
    Jul 2010
    548
    Hi Guys, Thanks for the vote of confidence. I try hard to help where I can.
    don't hesitate to PM or call me with your questions, I am here to help.
    Sportybob
  1. Replies: 1
    Last Post: 05-03-2013, 12:42 AM
  2. Spindle enable only cycled AFTER direction change
    By zerodegreec in forum Mach Software (ArtSoft software)
    Last Post: 03-01-2013, 06:50 AM
  3. Explorer Spindle Enable
    By johnhb in forum Bridgeport / Hardinge Mills
    Last Post: 10-30-2008, 06:28 PM
  4. V2XT: Spindle Enable dead fault.
    By 9 1/2 in forum Bridgeport / Hardinge Mills
    Last Post: 03-24-2008, 03:57 PM
  5. Spindle enable alarm Fanuc OTB
    By hien100881 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-21-2007, 08:29 AM
