Hey guys, hoping I can get some help. I have a 97 Fadal VMC 15. I had a #17 error on the Y axis the other day so I checked the voltage coming off the resolver and it was low so I pulled the resolver and installed a new one. After installing it I still got low voltage so I double checked the connector and noticed the molex connector had a broken connection. So I fixed that but now when I power up I immediately get this AXIS CONTROLLER DOES NOT RESPOND message that just scrolls and scrolls. There's no way for me to get past it. There's also no thump in the back when I hit the green button.I've pulled and unplugged all the axis cards and swapped the x and Y but I'm getting the same thing. Voltage coming from all the resolvers are reading right now. I installed a new axis card on the Y and it didn't help. I've swapped them all around and it doesn't help. I have no blinking lights on the amps. Anyone know whats up?
Is the relay not kicking on because of the error or could the error be because the relay isn't coming on? Any help would be great. Thanks guys
